12:1 CR safe for 91 octane?
Sushi Buffet Champion
I did I search but got mutiple answers. Some say 12:1 is too high for 91 octane, and some say 12:1 and 91 octane would be fine with the right tunning. Can you guys tell me if I can run 12:1 CR in a SOHCvtec with 91 octane? What's the downfall? I know 11:1 CR is ideal with 91, but is 12:1 pushing it too far for 91? Thanks.
[Modified by GTI 1.8t, 10:47 PM 12/28/2002]
Ask anyone from IB about it and this is what they'll tell you:
"It all depends on the tuning."
Not only it's just do-able, but it has been done. They say 13.0:1 is very realistic too on 91 octane pump gas.
Jay Kim
Jay Kim
p29 pistons and z6 head i am assuming? Depends on cam and tuning. obd1, with a healthy overlap cam and 8-10 degrees base timing, you should be fine. Or, 14 degrees base timing and a CHEETAH programmed obd1 ecu with said NA cam.
Why not use a turbo type head gasket (thicker, drops compression some). Even with the overlap of the VTEC cam, the low rpm cam will be less tolerent of the 91 octane fuel especially at full throttle with that compression ratio. Im assuming the piston valve clearances will be adequate.
[Modified by dennisman17, 1:01 PM 12/29/2002]
.. and BTW, i dont think 91 is healthy for the motor.. If your planning on spending thousands of dollars for building a motor, why not spend the extra 10 CENTS per gallon on 93????
12.5:1 is ok with pump fuel @ 2700ft so I would guess you could run it where ever you are. Thanks to Kataku2K3 I'm planning on running 13:1 on pump fuel... it CAN be done.
Let me add to this question. I am planning on running a 75-150 shot of NOS via DP on my H22. I have acess to 93 and 94 octane gas and thats all I currently put in my engine now.
Knowing that I have a shot of NOS on tap(Along with an AEM EMS and a wideband O2 sensor for tuning)what would be the highest CR I can run safely?? I am also using a Stage 2 Skunk2 camshaft which has an intake lift of .505 so I know I may have to mill the indents on the pistons a bit. BUt thats beside the point. Anyway, whats the highest I can go with a large shot of NOS??
I have built dozens of 12.5 plus motors running 91 no prob.
tuning is key
tuning is key
tuning is key
What exactly do you guys mean by tunning?? Do you mean cams, cam gears, port and polish head, valves, springs, injectors, high flow header and exhaust.. What would you need to be able to run the engine correctly on pump gas??
tuning is key
Actually it's gonna be an OBD2 D16Y8 with D16A1 pistons.
What's the point of putting 12:1 pistons if you're going to cancel it with a thicker turbo gasket?
It is much cheaper to buy a thicker head gasket than to obtain a different head/piston combination...duh.
[Modified by GTI 1.8t, 2:42 PM 12/30/2002]
You will be closer to 13:1 with that combination, 12.8:1 to be exact.
HoOridin
Sep 29, 2004 10:26 PM
