Honda flywheel weights
Old Dec 28, 2002 | 10:44 AM
dennisman17's Avatar
Default Honda flywheel weights
Could some give a definative answer to the F.W. weights of an ITR and GSR? Possibly refer to a site with these specs. Tnx
Old Dec 28, 2002 | 12:20 PM
hybridb18's Avatar
Default Re: Honda flywheel weights (dennisman17)
dont know if this helps but i just weighed 96 ls and it 17lbs, and a 1st gen b16a flywheel and it was also 17lbs.
Old Dec 28, 2002 | 12:29 PM
Default Re: Honda flywheel weights (hybridb18)
I seem to recall reading that the GSR FW is 14.5 Lbs and the ITR 12 Lbs. Someone Im purchasing an ITR wheel from said that they are about 5 lbs heavier than I thought. Just trying to get the #s right. Tnx
Old Dec 28, 2002 | 01:52 PM
Evolsport's Avatar
FYI: I just switched over to a Type-r Flywheel from a GS-R one....the GS-R flywheel was almost 18 lbs and the Type-R was almost 15 lbs..but the 3 lbs was taken off the outer part of the flywheel where it matters the most.
Old Dec 28, 2002 | 02:03 PM
Volcom's Avatar
Default Re: Honda flywheel weights (Evolsport)
Was it worth it? I'm looking into maybe upgrading the FW also. did it make a huge difference? Thanks
Old Dec 28, 2002 | 07:17 PM
Evolsport's Avatar
Default Re: Honda flywheel weights (Volcom)
Yes....I think it was well worth it...I got mine for $100. I heard that for every pound you take off your flywheel is like taking 10 pounds off of your car.
Old Dec 28, 2002 | 08:23 PM
sauceman's Avatar
Yeah, well actually, not exactly so. I remember the guys in SCC coming up with a formula to calculate those gains, but I don't remember when. You will feel the gains mostly in 1st gear, in 2nd gear, divide by at least 2, and so forth for every higher gear. 3 pounds should make a difference in 1st and 2nd gear, but you should hardly feel any difference in 3rd, 4th and 5th.
Old Dec 29, 2002 | 05:10 PM
gvillehnut's Avatar
I have a 7lb fw and it helped my revs tremendously. They rise and fall very quick. It helped through 1-4 of my short b16 gears.
Old Dec 29, 2002 | 07:27 PM
sauceman's Avatar
Default Re: Honda flywheel weights (black90b16)
Ooh Baby! 7lbs... I believe you. I have a 10 pound fw down from 20, and I too was amazed with the progress it gave. I can just imagine what it would be with a 7 pounder. Tell me, what was the OEM weight? Any downsides at all with the 7 lbs, like a rough idle?
Old Dec 29, 2002 | 07:43 PM
gvillehnut's Avatar
Default Re: Honda flywheel weights (sauceman77)
Its a clutchmasters for a b16. Apprx. 7-8 lbs. I vibrate a bit idling but im having some small idle problems right now anyway because of o2 problems but even with that its not bad at all. I love the thing.
[Modified by black90b16, 11:46 PM 12/29/2002]
Old Dec 29, 2002 | 08:10 PM
sauceman's Avatar
Beautiful
Old Dec 29, 2002 | 10:06 PM
Volcom's Avatar
How much of a difference do you think I'd feel from a stock 18#'s to 12.5? I'm still thinking about the aftermarket flywheel with the new clutch package that I'm going to install in the next couple of days?
Old Dec 30, 2002 | 06:08 AM
WAFFLES's Avatar
The ITR flywheel is 15lbs. If you look at the flywheel it actually has a little raised marking on it that says "15". And just as the guy in a previous post says, it ways almost 15lbs.
I didn't put either on the scale, but the R flywheel feels much lighter then a B16A flywheel.
Old Dec 30, 2002 | 07:34 AM
gvillehnut's Avatar
You should feel a difference comin down to 12 lbs. If youve got the money id say why not go a little lighter. I wouldnt hurt. I purchased mine off ebay for 275$ + shipping.
Old Dec 30, 2002 | 07:49 AM
Kev95lx's Avatar
7-8lbs!? How is that for daily driving?!
Old Dec 30, 2002 | 08:16 AM
gvillehnut's Avatar
Default Re: Honda flywheel weights (Kev95lx)
I have a cm stage 4 clutch bolted onto this and i thought i was going to have a very hard time daily driving but its not bad at all. I just have to keep my revs up a little more to get it to catch without jerkin my head back lol.
Galaxy Si
Jan 18, 2005 06:56 AM
MugenDC4
Jul 18, 2004 09:27 PM
Rhetoric
Aug 12, 2002 05:31 PM
1phatGSR
Jan 27, 2002 10:36 PM
ITS BONE STOCK I SWEAR
Jul 5, 2001 12:56 PM
