Cam Seals Tech.
Old Dec 28, 2002 | 08:47 AM
2muchPSI's Avatar
Default Cam Seals Tech.
Hey, im going to be replacing the cam seals today, anyone have any experience with this on a b series engine? What do i torque the "screws" back to, and help would be appreciated. Thanks.
Old Dec 28, 2002 | 08:49 AM
1bad-eg's Avatar
Default Re: Cam Seals Tech. (92tealvx)
Just make sure that the seals go in evenly or you can have a nasty oil leak. What kind of engine is it?
Old Dec 28, 2002 | 09:36 AM
2muchPSI's Avatar
Default Re: Cam Seals Tech. (1bad-eg)
it is a b17 engine, out of a 92gsr
Old Dec 28, 2002 | 05:54 PM
vhd's Avatar
vhd
torque the inside cam cap bolts to 16 lbs./ft., and torque the two bolts at each end (cap # E1, E5, I1, and I5)on both the intake and exhaust side to 8 lbs./ft., they should be smaller then the rest.
Old Dec 29, 2002 | 06:25 AM
boosted3g's Avatar
Default Re: Cam Seals Tech. (vhd)
When you use Hondabond to seal them also go a little out of the journal and onto the flat area under the cam cap and around the bolt holes. The cam seals are prone to leak.
Old Dec 29, 2002 | 06:45 AM
PhatOptimo's Avatar
Default Re: Cam Seals Tech. (boosted3g)
The cam gear bolts torque is 37 ft. lbs.
Old Jan 4, 2003 | 12:54 AM
2muchPSI's Avatar
Default Re: Cam Seals Tech. (Phat_Optimo)
my manual says the cam gear bolt is 27 lbs? Is that correct
Old Jan 4, 2003 | 01:46 AM
HOOKUPS-PRO-CRX's Avatar
the 12mm cam cap bolts are 16ft lbs and the 10mm cam cap bolts are 7.2lbs.
Old Jan 4, 2003 | 04:39 AM
b19coupe's Avatar
It is not necessary to remove the cams to replace the cam seals. If you do, the 12mm cam cap bolt spec is 19 ft./lbs. The 10mm bolt torque spec is 7.2 ft./lbs which I round up to 8 ft./lbs. I am pretty sure that the cam gear bolt torque spec is higher than either of the torques listed in previous posts. I am going into work later and i will post it for you. I think it's around 45 ft./lbs. , but I will let you know for sure later.
Old Jan 4, 2003 | 04:44 AM
google's Avatar
Default Re: Cam Seals Tech. (b19coupe)
helms it would solve all ur problems
Old Jan 4, 2003 | 11:37 AM
juicedricer's Avatar
Default Re: Cam Seals Tech. (1320in11)
yea the motor i have has a cam seal leak that i will be needing to fix. cant wait to fix it and get it on the road
Old Jan 4, 2003 | 11:49 AM
BuddhaSiR's Avatar
Default Re: Cam Seals Tech. (juicedricer)
if you're simply replacing the camseals and nothing more, I wouldn't remove the cam caps. waste of time.
Old Jan 4, 2003 | 12:12 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Cam Seals Tech. (BuddhaSiR)
careful not to tighten em down to tight prone to busting (broke 1 today and last week! well a lil longer then last week) the keeper bolts.
Blaze
Old Jan 4, 2003 | 12:59 PM
b19coupe's Avatar
Default Re: Cam Seals Tech. (Blaze45)
Cam gear bolt torque-B18B = 27 ft./lbs.
B18C = 41 ft./lbs.
Old Jan 4, 2003 | 03:04 PM
fixhondas's Avatar
Don't remove the caps- it is very easy to pinch the edge of the seals when you reinstall the caps and they can leak. Just remove the cam gears and pull out the old seals with a pick or small screwdriver. Lube the new seals with some grease (especially on the lip) and install them by placing them by hand and then push on them with the open end a properly sized socket or something similar (like a deep 27mm or something). A little grease on the outside of the seal will help it slide in easily.
Old Mar 18, 2003 | 06:21 PM
Fuster_Cluck's Avatar
Default Re: Cam Seals Tech. (fixhondas)
Can someone tell me how many cam seals are on a 98 GSR? I've decided that I am going to replace them while the motor is out and I am knocking the timing belt, water pump, etc....
Thanks!
Old Mar 18, 2003 | 06:46 PM
smokey2.0's Avatar
Default Re: Cam Seals Tech. (Hybrid93Hatch)
Can someone tell me how many cam seals are on a 98 GSR? I've decided that I am going to replace them while the motor is out and I am knocking the timing belt, water pump, etc....Thanks!
there are three, two by the timing belt. one on the intake cam, and one on the exhaust cam! the third one is, on the exhaust cam next to the distributor. Looks like a rubber plug!
oldskoolaccord
Apr 14, 2009 06:22 PM
LSR-Abuser
Oct 1, 2007 09:11 AM
B16Civic93
May 20, 2007 10:46 AM
Tim2179
Aug 29, 2005 02:26 PM
Tim2179
Aug 28, 2005 06:02 PM
