y8 aem camgear???
Old Dec 28, 2002 | 06:08 AM
1.8Tities's Avatar
Default y8 aem camgear???
I found a guy who's selling an aem adj camgear and i would like to know if i can use this into my A6? Are they the same or the y8 has less or more teeth than the a6 cam gear???
Old Dec 28, 2002 | 06:48 AM
PaImportTuner's Avatar
Default Re: y8 aem camgear??? (4thGSi)
NOPE... 88-95 cam gears are the same, 96-00 are different
Old Dec 28, 2002 | 07:42 AM
essex's Avatar
Default Re: y8 aem camgear??? (PaImportTuner)
Why can't he use??? He can compensate for the diff in timing because its adj.
Old Dec 29, 2002 | 02:05 PM
Default Re: y8 aem camgear??? (essex)
well considering that IF its one tooth off its like 8degrees off (I dunno if the y8 gear is larger in diameter or less/more teeth) and that would DEFEAT the whole purpose of having an Adjustable GEAR.. cause doesnt it advance and retard only 10-12degrees so he has 4 degrees to play with..??? instead of 12 to play with cause he's "compensating" for it not being the right gear.
I really dont know much about timing, quite frankly i hate messing with it. So my suggestion is pay the little fee of a new one for less then $100 to avoid a headache worth $400++
Just go on EBAY or GBC and get an AEM/OBX/Skunk?whatever for ~95 shipped.
Old Dec 29, 2002 | 03:21 PM
slowman's Avatar
I took way too long
the 96 and up are off by 5 or 6 degrees so adjust it accordingly, but it would work.
Old Dec 29, 2002 | 03:53 PM
89civicdx's Avatar
Default Re: y8 aem camgear??? (slowmanEF)
if its one tooth retard then put it one tooth advance ...if you are getting it for cheap then go fo it. Remember though their is no point in having a adj gear without a timing light especially if the timing is off stock being that it is y8 gear.
Also I don't know too many people who need 10 degrees of adj
CrX EnTHUSIAST
Engine Machining & Assembly
Sep 7, 2017 10:01 PM
dudenhymer
Oct 21, 2010 04:46 PM
RACEPAK
May 15, 2010 10:59 PM
90LSpimpin
Jan 31, 2005 01:34 PM
BauleyCivic
32
Jul 4, 2004 02:56 PM
