Valve Cover Gasket install
Old Dec 28, 2002 | 05:06 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Valve Cover Gasket install
is it difficult to do this?
I just got a new motor put in and my stupid mechanic didn't do it
It is the 4 screws and the spark plugs right
then it comes up the valve cover?
Old Dec 28, 2002 | 07:46 AM
EG8R's Avatar
Default Re: Valve Cover Gasket install (crxecution)
Put some silicone or soemthing on the corners of the seal where the cover is cut to go over the cam....
Old Dec 28, 2002 | 11:09 AM
Ef Whore's Avatar
Default Re: Valve Cover Gasket install (mr. skelly)
there is no need for silicone if u get a oem honda gasket like u should....fel-pro might be a different story.
Old Dec 28, 2002 | 11:44 AM
altoid's Avatar
Default Re: Valve Cover Gasket install (Ef *****)
even if you get a honda gasket you still are told to use honda gasket sealer to put it where the sharp corners are on the head...its standard protocol and it beats doing it right the second time around
Old Dec 28, 2002 | 01:28 PM
EG8R's Avatar
Then why do the guys at my work do it??? Because they may leak if you don't.... No matter who makes the gasket....
Old Dec 28, 2002 | 11:41 PM
stockcrx's Avatar
i like honda bond. trusty honda approved stuff.
Old Dec 29, 2002 | 07:52 AM
MugenHonda's Avatar
Default Re: Valve Cover Gasket install (JDM EF9)
what i want to know is that all i need to take off is the 4 main screws and 3 spark plugs and the valve cover will come off?
Thanks
Old Dec 29, 2002 | 12:35 PM
altoid's Avatar
Default Re: Valve Cover Gasket install (MugenHonda)
yes, take the 4 screws out and the four plugs and grip it firmly and pop it off. Make sure you clean off the cyl. head properly where the gasket was. Don't scrape it with chisel or whatever
specbb6
Dec 15, 2011 11:21 PM
2k_Si
Feb 16, 2009 07:03 AM
rasinhell
Aug 8, 2005 01:00 PM
dmxsoulja3
Mar 12, 2005 07:33 PM
KOALA YUMMIES
Oct 29, 2002 06:44 PM
