yet another oil feed/return question...did search
Old Dec 27, 2002 | 11:24 PM
ash.zero's Avatar
Default yet another oil feed/return question...did search
i searched for over 30 mins on this slow 56k modem and i could not find earl's part number and instructions for t3/t04e...
i'm sorry for bugging people about these "dumb" questions...but i really couldn't find the info from search...few pointers would be tremendous...thanks!
also, i considered buying their oil kit...how are they? anyone have any experiences?
http://www.turbo-performance.com/Pro...l-linekits.htm
Old Dec 28, 2002 | 06:27 AM
boosted3g's Avatar
Default Re: yet another oil feed/return question...did search (ash.zero)
What fittings exactly are you looking for and what method are you planning to tap for oil. I like using the GE vtec conversion kit. Its basically an extremely nice sandwich adapter that has 1/8 npt threaded holes (the same as your oil fed on your turbo). I use the flange on the return of the turbo and that is 1/2 inch npt if im not mistaken.
Old Dec 28, 2002 | 11:28 PM
ash.zero's Avatar
Default Re: yet another oil feed/return question...did search (boosted3g)
ok, i found this great thread...
https://honda-tech.com/zerothread?id=268110
after reading up for a while, i assembled a buy list for the oil return for t3/t04e (50 trim) with drag 4 mani on f23a (accord 4cyl)...is this complete? just making sure someone can stamp a seal of approval before i proceed...
also, can i get away with 1 feet? or should i go for 2 feet just in case? is the hose difficult to cut? if not, i'll just get 2 feet to be safe...
here is the list:
Adapter 997110 $5.11 ea. 1 $5.11
Adapter FCM2009/981610 $4.85 ea. 1 $4.85
Aeroquip Hose FBA1000 $5.79 ea. 2 $11.58
Hose End 804610 $23.39 ea. 2 $46.78
thanks guys...
[Modified by ash.zero, 8:28 AM 12/29/2002]
Old Dec 28, 2002 | 11:39 PM
lucas569's Avatar
Default Re: yet another oil feed/return question...did search (Blake)
i used a greddy oil sandwhich adapter, goes in back of the block inbetween the filter. works great.
Old Dec 28, 2002 | 11:40 PM
lucas569's Avatar
dude, plz change ur ******* avatar, I can get fired if my boss or a customer sees that while i'm surfing ht.
your at work! shouldnt you be WORKING?
Old Dec 29, 2002 | 12:08 AM
ash.zero's Avatar
ok, i ordered it...
blake: well, i would change it, but i don't have anything else to use as an avatar at this moment...hope you didn't get fired
MantisX
Sep 14, 2007 06:36 AM
BlackRocket
May 16, 2005 08:30 AM
boostin b16
Mar 15, 2003 05:44 PM
iperez
Jan 18, 2003 04:36 PM
Ri5e
Jun 20, 2002 10:41 AM
