Whats the best spring rate?
Old Dec 27, 2002 | 09:41 PM
VegasHatch's Avatar
Default Whats the best spring rate?
I have a 95 civic dx hatch. I am dropping a b18c1 in it shortly and I plan on taking it to the drags and using it as my daily driver. I dont mind if the ride is a bit harsh. I am buying Ground control coilovers and I need to know what would be the best spring rate for me.
Old Dec 28, 2002 | 08:47 AM
1bad-eg's Avatar
Default Re: Whats the best spring rate? (VegasHatch)
About 450 in front and 350 in rear should give you a pretty good ride.
Old Dec 30, 2002 | 03:33 PM
PupaScoopa's Avatar
Default Re: Whats the best spring rate? (1bad-eg)
There is no "best" spring rate. It will depend on the surface you're driving on. Don't assume that higher spring rates will give you better handling. If it's a perfectly smooth track, you can run very high rates. If you hit a series of bumps on that track, you'll be all over the place. On a daily driver, comfort is also important.
I agree with 1bad-eg about 450/350 MAX. I run a little lower and it's still a little harsh sometimes.
Old Dec 30, 2002 | 04:32 PM
MrFatBooty's Avatar
What (if any) sway bars are you running?
Mr.EM1
Suspension & Brakes
Mar 4, 2005 10:09 AM
b18crx
Nov 14, 2003 06:12 PM
JapSpec954
Jun 13, 2003 02:44 PM
VegasHatch
Dec 28, 2002 04:45 AM
