quick question on turbo timer install...did search
Old Dec 27, 2002 | 07:16 PM
_Endless_'s Avatar
Default quick question on turbo timer install...did search
i got a blitz fatt dc turbo timer. there are 5 wires: constant 12v, ignition, accessory, ground and e-brake.
on my civic, there's 2 ignition, black/yellow-ig1 and yellow-ig2. i tap the ignition from the turbo timer to the black/yellow wire right now. my question is, do i also need to tap into the yellow ig2 wire? in short, are both the ig1 and ig2 wire tap into the ignition wire of the timer or the ig1 will do?
Old Jan 4, 2003 | 09:43 AM
EG6owner-T's Avatar
Default Re: quick question on turbo timer install...did search (_Endless_)
what wire will u tap for the ig2?
everyone here just connected the ig1
let me know how it turned out
Old Jan 5, 2003 | 09:50 PM
_Endless_'s Avatar
Default Re: quick question on turbo timer install...did search (EG6owner)
well, i just tap to ig1 but the problem is, after i installed the msd 6a, the engine always stall for a few millisecond then immediately idles to 1500rpm then to normal idling when ever the turbo timer activates. i didn't have this problem when the msd is not yet installed.
skyman88
Jul 19, 2004 11:32 AM
Lenthrax
Jul 14, 2002 02:33 PM
SolidSpruce
May 6, 2002 06:59 AM
Smashback
Apr 11, 2002 11:44 PM
