O2 code being thrown ?????
Old Dec 27, 2002 | 05:51 PM
bumpin_bass's Avatar
Default O2 code being thrown ?????
I was driving in 5th gear at about 1800 RPMs and my check engine light popped on, I checked the code and it is throwing code 1 oxygen sensor. Is the sensor bad or is this something to do with going to slow in 5th?
Old Dec 27, 2002 | 05:53 PM
Dual Cams's Avatar
Default Re: O2 code being thrown ????? (bumpin_bass)
its nothing major... try to reset your computer and if that code pop up again than try to replace a O2. hit me up if you have any other questions
Old Dec 27, 2002 | 08:06 PM
nolimits's Avatar
If you need to replace the o2 here's a good source http://www.oxygensensors.com
Old Dec 27, 2002 | 11:06 PM
Default Re: O2 code being thrown ????? (Dual Cams)
The next time I started the car the CEL wasn't on and I drove around and it didn't come on, but then I let it sit for awhile and drove it again and the CEL came back on when I was flooring it. Any ideas? Or is it just time for a new o2?
Old Dec 27, 2002 | 11:15 PM
nickcrx929's Avatar
listen for your main relay going on and off, you should hear a clicking sound when you get the code, if this happens check your ground leads around your engine (thermostst). Does your engine sort of hesitate when you get this code, and do you only get this when you accelerate hard, if so check your grounds.
Old Dec 27, 2002 | 11:25 PM
Default Re: O2 code being thrown ????? (nickcrx929)
My thermostat is bad, could this affect the o2? Today is the first day that it has thrown o2 before it was throwin IAT but I fixed that then it ran fine for a couple of days and now o2?
Old Dec 29, 2002 | 12:00 AM
Could the length of the wires connecting the o2 to the wire harness affect anything?
Old Dec 30, 2002 | 05:53 PM
ttt
Spug
May 26, 2012 12:15 AM
DarkBB4
Aug 27, 2005 09:31 AM
BigBoyJohn
Dec 26, 2003 11:35 AM
Qwikrex
Jun 22, 2002 12:52 PM
ARACER25
May 15, 2002 08:19 AM
