i think i figured out the constant shaking in my car, read on.
Old Dec 27, 2002 | 12:53 PM
Ideal's Avatar
Default i think i figured out the constant shaking in my car, read on.
As some of you know, ive had this really bad shaking in my car for a while, did the whole tune-up thing, didnt fix it, replaced pcv valve, helped a bit, but nothin really, and then i noticed on the drive to tijuana today(live about 3 hours away) that everytime i used my automatic windows, the car would start to shake. Then a about a hour later, it fellt like my A/C turned on, although it wasnt, so, im thinking that the FAN that is used to cool the car turned on, which drained some energy, like the window, and made the car shake
What do you guys think?
Opinions/Suggestions.
-Jon
Old Dec 27, 2002 | 03:12 PM
93accordEX's Avatar
Default Re: i think i figured out the constant shaking in my car, read on. (Ideal)
possibly bad alternator, but I don't know much about the electrical system.
Old Dec 27, 2002 | 06:59 PM
Gus's Avatar
Gus
My 92 DX is doing something similar, but no shaking. When the cooling fan clicks on, my dash lights dim just a bit. The fan also squeels a bit, so i'm guessing the bearings are going and it's harder to turn so it's pulling more power to turn it. A new fan would seem to be the easy fix.
Though with what you describe, it would seem to be a problem with the alternator. Does it just shake at idle, or anytime you use an accessory at any speed?
[Modified by tardis, 4:03 AM 12/28/2002]
Old Dec 27, 2002 | 07:33 PM
Razor's Avatar
Default Re: i think i figured out the constant shaking in my car, read on. (tardis)
change your altenator
Old Dec 27, 2002 | 10:52 PM
TypeSH's Avatar
does it shake while driving? at idle? my car shakes a lil too when stopped at idle and when i use the windows or ac. for me, getting on the gas a lil to bring the revs up and it would stop shaking.
Old Dec 27, 2002 | 11:56 PM
Ideal's Avatar
Default Re: i think i figured out the constant shaking in my car, read on. (TypeSH)
nah, i recently did the motor mounts, and it didnt help, yeah, it occurs only at idle, if i raise my rpms it dies down to... im guessing alternator, but im not sure, i kneed more suggestions, maybe battery?
How much do alternators run, 50-60 bucks?
-Jon
Old Dec 28, 2002 | 04:30 AM
sauceman's Avatar
Definitely your alternator if it's at idle. Change it. I guess it's a little more than 60 bucks. I had a rebuilt put on last summer an it cost over 200$
Old Dec 28, 2002 | 05:27 AM
Chiovnidca's Avatar
Is it a five speed or and auto?
Old Dec 28, 2002 | 12:54 PM
cyrixvsp2's Avatar
Default Re: i think i figured out the constant shaking in my car, read on. (Chiovnidca)
well, that would put a draw on your engine and cause the rpms to be slightly lower (using power). Your idle should compensate for that though after about a second or 2. If anything it'd be your alternator not putting out enough power, DEFINATELY not your battery. common misconception, your battery shouldnt' be doing anything except being charged when your car is running. if you are drawing current from the battery that means your alternator isn't putting out enough current to supply your car with what it needs.
Old Dec 28, 2002 | 05:30 PM
Ideal's Avatar
Default Re: i think i figured out the constant shaking in my car, read on. (cyrixvsp2)
and i have an auto, can anyone direct to somewhere online to buy and alternator?
-Jon
Old Dec 28, 2002 | 06:30 PM
Chiovnidca's Avatar
and i have an auto,
Have you checked the operation of your rear motor mount? It's vacumn operated.
Have someone hold it in gear and disconect the vacumn soleniod connector. If the system is working, the vibration should be worse with it disconnected. I doubt the problem is with your alternator.
Old Dec 28, 2002 | 07:04 PM
Ideal's Avatar
i actually replaced the rear motor mount.
Old Dec 28, 2002 | 07:13 PM
Chiovnidca's Avatar
Yea, i saw that in one of your earlier posts. So did you you check to make sure it's working?
Old Dec 28, 2002 | 07:17 PM
Ideal's Avatar
guh... no not really... so if i do your test, would that mean i kneed to install a new one? or just get a soleniod?
-Jon
Old Dec 29, 2002 | 05:28 AM
Chiovnidca's Avatar
-Jon
That test is just to see if it is working or not.
Old Dec 29, 2002 | 09:35 AM
Ideal's Avatar
where is the soleniod connector?
-Jon
Ideal's Avatar
Where is the soleniod connector? Up by the pcv valve?
Old Dec 29, 2002 | 11:20 AM
Chiovnidca's Avatar
-Jon
On the soleniod. Follow the vacumn line up from the mount, it goes right to it.
snowman2876
10
May 14, 2010 10:20 AM
95silverluder
Sep 19, 2007 04:42 AM
lowered94accord
Aug 29, 2007 10:05 PM
bb4socal
Jan 5, 2006 02:24 PM
Mike_C
Oct 15, 2002 10:03 AM
