Need help with b16 bottom end build?
Old Dec 27, 2002 | 12:11 PM
-16V-'s Avatar
Default Need help with b16 bottom end build?
Ok here's the scoop i have a b16a block for a n/a setup that needs to be built soon.
So here's a list of stuff i got for the block assembly, And block work....
Block work:
balancing the (WHOLE) bottom end.
Rods,crank,pistons,flywheel,crank pulley.etc
Honing the cylinders
Cleaning the block
Buying for the block:
Piston rings
Rods bearings
Main bearings
I guess thats it, Let me know what you think?
Is that too much for a n/a setup, Am i missing anything?
Old Dec 27, 2002 | 12:45 PM
-16V-'s Avatar
Default Re: Need help with b16 bottom end build? (1991_jdm_sleeper)
What color code do i need for a jdm b16a rod bearings and main bearings?
[Modified by 1991_jdm_sleeper, 10:41 PM 12/27/2002]
Omegax10
Mar 31, 2012 12:11 AM
DawgC2
Engine Management and Tuning
Jan 2, 2012 11:38 AM
mountaindewguy
Oct 18, 2006 10:13 AM
BoOsTiN Dc2
Mar 15, 2004 06:47 PM
