Tune up?(what do i need)
Old Dec 27, 2002 | 10:31 AM
VtechMixedKorean's Avatar
Default Tune up?(what do i need)
What all do i need to do a tune up Spark plugs Wires, Do i need the distributor Cap and Rotor? Fuel and Air Filter And do i need to Serive my Fuel Injection by Cleaning my Throttle Bore And Idle Passage it sounds hard i dont know what to do only the Wires and Spark Plugs. Do i need any of those other things? I mean when u take your car to get a tune up what do they normally do?
Old Dec 27, 2002 | 11:55 AM
Default Re: Tune up?(what do i need) (VtechMixedKorean)
Old Dec 27, 2002 | 11:59 AM
Desslok's Avatar
For tune ups I usually pick up spark plugs, oil, oil filter, tranny fluid, cap , rotor, air filter(unless you have CAI, then just clean and re oil), fuel filter, some beer, and Slim Jims. I also check the timing and idle. Also check coolant.
Old Dec 27, 2002 | 01:31 PM
Default Re: Tune up?(what do i need) (sp)
So i can do da spark plugs and oil tranny fluid.....but is the cap and rotor hard to put on and do i dont even know what it i. and what does CAI stands for i am like new to this fixing up my stuff i know ya'll going to pick on me but ya'll were once there before and fuel filter dat is hard i think where is that located at. Beer and Slims jims sound good as hell and how do u check the timing and idle on this car o and if ya dont know it is a 93 accord LX. Stock.
Thanks
Old Dec 27, 2002 | 09:27 PM
iam7head's Avatar
CAI=cold air intake!
the old and cleaner are sold as a package. for K&N reusable filter.
lol "vtech"
vtech is a phone company...
vtec is honda's
just a friendly reminder
[Modified by iam7head, 6:28 AM 12/28/2002]
Old Dec 28, 2002 | 01:11 PM
cyrixvsp2's Avatar
Default Re: Tune up?(what do i need) (iam7head)
cap and rotor is simple. you get it as a combo from autozone. i just did mine and it was like 25$ total. the cap and rotor are on the left of your engine when you are looking at it. it's the black thing that the spark plug wires plug into. i don't know what kind of car you have because you didn't mention (put it in your sig so people know) so i'll assume it's an internal coil like mine. here is what the cap and rotor is:
now, it's simple, there are 3 bolts to take it off, they are 8mm or you can use a philips head screwdriver. i suggest leaving all the plugs on the cap when you remove it, then taking them one by one off of the old cap and putting htem on the new one. that way you don't mess them up. Then, when you have that off, there is a round thing in there with a contact on one arm of it. that's your rotor. it's in this picture here, the black plastic thing:
edit: disreguard the writing in that picture, it's from another website showning how to change the ignitor. i used hte picture just to show the rotor to you. don't remove any wires.
use a flathead screwdriver and it should just pry off (some have set screws in them so feel around to see if there is a screw, if not, you juse use a flathead and gently pry it off). then you press the new one back on (there is only one way it fits) then you put the cap back on and tighten the 3 small bolts back and you're ready to go. oh ya, don't forget to use the new seal included with the cap and rotor you bought.
that's all there is. e-mail if you need more help.
[Modified by cyrixvsp2, 5:12 PM 12/28/2002]
KevinEJ6__17
Jul 6, 2014 01:55 AM
JDMxSpawn
Oct 26, 2005 11:02 AM
coupon
Jun 2, 2005 09:56 PM
ieatrice
13
Jan 27, 2004 12:02 PM
Hybrid Boy
Sep 1, 2002 03:16 PM
