where is your factory temp needle sitting at during regular driving?
Old Dec 27, 2002 | 03:39 AM
Charlie Moua's Avatar
Default where is your factory temp needle sitting at during regular driving?
Call me peronoid but ever since i swaped out my theromostat (got a NAPA one)
the temp needle seems to sit higher than before.
-now while driving in the WINTER my car needle is barley touching the 1/2 mark. And if it stop and go traffice.... the needle goes up pass the 1/2 mark.
-before when i had my factory one it wouldn't even sit at high even in a long *** road trip or on hot summer days.
***is this somthing i should be worried about?
-what is your needle sitting at?
-is this safe for my motor to be this hot?
---when summer gets here i'm assuming that the temp will get even hotter.
does anyone know where to get a lower temp thermostate?
Old Dec 27, 2002 | 04:04 AM
Stew Pidasso's Avatar
Default Re: where is your factory temp needle sitting at during regular driving? (Charlie Moua)
My needle sat under the halfway point. It really shouldn't move past that at all. Your cooling system should be able to maintain that operating temp. You may have a hotter (opens at a higher temperature) thermostat. Are you sure your fans are kicking on? Are you losing any coolant?
Old Dec 27, 2002 | 04:53 AM
Default Re: where is your factory temp needle sitting at during regular driving? (Stew Pidasso)
NO i am not loosing any coolant.
how can i check to see if my fan is kicking on? (when does it turn on?
Old Dec 27, 2002 | 08:38 AM
RotaryBzzz's Avatar
what brand did you use from NAPA? When I did mine, I sprang for a TAMA (made in Japan) OE-type one. It works like clockwork...once it's goes to operating temp, I can't get it to move anywhere..even in heavy traffic in summer weather.
While I don't have anything against non-japanese parts, i've seen some pretty crappy stuff come out of misc auto-part places.
Old Dec 27, 2002 | 09:32 AM
If your temp needle is high and your fan is not on yet, your problem is there. Also, make sure there are no air pockets in the cooling system.
Edit: You may want to try a different thermostat too. That one may be defective. Get a quality one.
[Modified by Stew Pidasso, 1:36 PM 12/27/2002]
Old Dec 27, 2002 | 07:26 PM
Gus's Avatar
Gus
The thermostat you got should be a 185 degree one. That's what was stock on my 92 at least. The $11 one I got at Pep Boys has worked perfectly for me. The needle sits just below the middle and doesn't move. And it could be your cooling fan isn't turning on. Check that. Could be the sensor that tells it to turn on. It should turn on when your coolant hits 200 I think. Though it may be lower than that. And yes, running hotter than it is supposed to will hurt an engine over time.
Old Dec 28, 2002 | 09:59 PM
briq4's Avatar
Default Re: where is your factory temp needle sitting at during regular driving? (tardis)
my 93 EX stays right at the center of the range. It's the original thermostat and has 251,000 miles on it so far.
Old Dec 28, 2002 | 10:05 PM
briq4's Avatar
Default Re: where is your factory temp needle sitting at during regular driving? (briq4)
P.S. genuine Honda thermostat is around 11 bucks (for a 93 Accord anyhow)
Old Dec 29, 2002 | 05:25 PM
so how do i make sure that all the air pocket are out?
MrBigMac
Honda Civic (2001 - 2005)
May 15, 2016 04:25 PM
LAO
Jun 3, 2008 06:24 PM
Chuethou_b18c5
Mar 15, 2007 10:46 AM
allmotor.net
Apr 24, 2003 02:58 AM
