home madeturbo not runnin right
Old Dec 26, 2002 | 05:12 PM
project dc2's Avatar
Default home madeturbo not runnin right
ok .. break it down ...
89 honda civic Si
93 D16Z6
home made turbo kit, 3 inch exhaust, ACT clutc, flywheel, DIY VTEC controller ( summit RPM switch), alright anwyays, well we swappe din the motor and its been runnin like ****, one of mjy DSM buddies suggested switchin aroudn the coolant sensor on the back of the block, might have mixed up teh wires, tried it, WOOHOO ! it works, my friedn geos around the block and one of his charge pipes popp off, but then the rest of the day the car drives fine.
dilemma- the car bogs to **** at 4K before i swtiched around the coolant sensor * 2 prong* and the temp gauge went up with the boost, kinda like a boost gauge, that symptom is gone now.
NOW, we fixed the caharge pipe and i tried to finish the exhaust but only got to the axle back ( 3 inch madnrel bent, no cat no muffler yet)
fuel sysytem consists of- stoCK !! with 450CC injectors and filetofit's chip to idle the large injectors ( worked well on the D16a6 until it overboosted n blew)
Soo .. now .. the car bogs and has no power waht so ever it would bogg and kinda stall but turn on and you could floor the car and it will jerk back and forth or have NO power what so ever., the lights are dim and barely light up, we jsut changed the starter and the altenator (* alteantor is known to be good) the car WONT start on its own, it has to be push started.
SOo .. yea .. ok .. big headache !! HELP >> ME !!!
Old Dec 26, 2002 | 06:32 PM
cock head's Avatar
Default Re: home madeturbo not runnin right (project dc2)
HI, I know you have the filetofit's chip but you might wana check it and see if its works right, because it sounds like you are running really really rich.
Kid-jdm-teggy
Mar 23, 2014 06:31 PM
MalcolmV8
Oct 15, 2011 10:01 PM
spotteddawg
16
Feb 18, 2005 04:44 PM
project dc2
Jan 9, 2003 07:07 PM
project dc2
Dec 26, 2002 07:17 PM
