What Size Socket to Remove Axles on 92 Accord?
Thanks bro! That's the size socket I rented the other day by memory, but I wanted to double check before I do the axle swap tomorrow...
Thanks!
Hank
Thanks!
Hank
LOL...so I've heard :D
What else do I need besides the axles and the socket? Any last-minute tips for doing this?
Thanks,
Hank
Thanks,
Hank
You can get a puller to loan for free from autozone, that way if you can't beat the ball joint off, you can try the puller out. And a metal coat hanger to hold the assembly up out of the way.
Be careful when you pull the axles. I did mine last winter and fubar'd one of the wheel bearings. Had to buy a new bearing and have it pressed on. Dented the wallet, to say the least. Got new axles at Checker for a reasonable price. Both CV boots were ripped and grease everywhere. Not a hard job. You need a good pry bar, also. Good luck.
It was VERY easy...
Impact wrench broke the 36 mm nut loose. Popped the lower ball joint and rotated everything out of the way. A slight pop with a pry bar and the axle was out and the new one was back in...
Thanks for the help guys!
Hank
Hank
nicky352
Jan 19, 2011 07:38 AM
Mike Panic
21
Sep 22, 2005 06:37 PM
