a 12v ignition source
Old Dec 26, 2002 | 02:54 PM
B18C-RnVA's Avatar
New User
Default a 12v ignition source
need to find the wire for 12v ignition source, to run my inline fuel pump. on a 1995 teg. if any of you guys can tell me what the color is to slice it on that would help me alot..thanks...
Old Dec 26, 2002 | 03:20 PM
speedymon's Avatar
Default Re: a 12v ignition source (B18C-RnVA)
you need to tap into a wire that is hot when in the #2 key position. The same position the stock pump comes on. You don't want your inline on all the time. I already showed you the wire you ricer.
Old Dec 26, 2002 | 05:43 PM
ImAcracker's Avatar
Loved
Get a test light.
Old Dec 26, 2002 | 06:49 PM
TEAMGENDAI's Avatar
Default Re: a 12v ignition source (ImAcracker)
ok 1995 integra love those cars!! ok to wire a inline fuel pump you will need a relay. ground the pump of course then get a normal bosch (or any other brand) relay. what what we are gonna do is called ground to circuit. Ground the fuel pump. hook pin 87 on relay to (+) of pump then hook pins 86 and 30 together and run directly to postive of battery or engine bay fuse box. then pin 85 you run inside the car where you will need to solder or tap.. perferably solder to ecu pin #A7 This is the correct way to connect a inline fuel pump. if you have any other question e-mail or im me.. i can e-mail some pics of how to do..
Old Dec 27, 2002 | 05:21 AM
B18C-RnVA's Avatar
New User
Default Re: a 12v ignition source (TEAMGENDAI)
teamgendai you have aPM and speedymon you showed me the wire, but then you said that you were not sure so you shut up ricer.
Old Dec 27, 2002 | 06:51 AM
RAWB's Avatar
On my 91, in the drivers side fuse box-there are 12v ignition posts. If you have a multimeter or test light, you can poke around your fuse box and see if you have the same.
Old Dec 27, 2002 | 08:20 AM
Ricky Rojales's Avatar
Get a Helm's for your vehicle while your at it, and a multimeter if you don't want to risk damaging something after testing the wrong wire accidentally.
Old Dec 27, 2002 | 12:45 PM
Doctor CorteZ's Avatar
just use the taps under the dash.
use a test light and find the switched power , thats what they're there for....
Old Dec 27, 2002 | 06:26 PM
salbaje's Avatar
look into the fuse box there will be some empty slots. if you got a test light just check in there.
pleej
Apr 8, 2011 11:06 AM
RICE POLICE SIP
Apr 21, 2010 03:26 PM
crxfreak1117
Aug 15, 2009 06:09 AM
DOHCarp
Apr 1, 2002 04:40 PM
Arturbo
Jan 27, 2002 02:34 AM
