Correct Foot Pounds? Help me out?
Old Dec 26, 2002 | 02:26 PM
2muchPSI's Avatar
Default Correct Foot Pounds? Help me out?
How many foot lbs of torque do the 20 bolts on the cam caps take, This is for a b17 engine out of a 92 integra. There are 10 bolts on each runner( each runner goes about each cam) I am unsure what to call these, but can someone please tell me how tight to tourque these down. I dont want them coming loose on me. Thanks
Old Dec 26, 2002 | 02:42 PM
Spade's Avatar
Default Re: Correct Foot Pounds? Help me out? (92tealvx)
I don't know but, you are looking for the "Torque Specs" of the cam caps.
Try a search using that.
Old Dec 26, 2002 | 02:52 PM
D-Man's Avatar
Tighten the 6mm bolts to 96 inch lbs
Tighten the 8mm bolts to 16ft lbs
always start from the middle bolts and work your way out
Old Dec 26, 2002 | 03:26 PM
sgT's Avatar
sgT
actually, the larger bolts are 19lbft and the small bolts are around 7.5
Old Dec 27, 2002 | 09:05 AM
2muchPSI's Avatar
So its 19 and 7.5? are u sure
Old Dec 27, 2002 | 09:14 AM
Spade's Avatar
I can vouch for sGT, he knows what he is talking about.
Old Dec 27, 2002 | 09:20 AM
D-Man's Avatar
I'm sure the spec's i gave you are for a 92 GSR 1.7L,I looked it up using Snap-on Shop Key software.....I dont know where he's getting his spec's from.
[Modified by D-Man, 1:22 PM 12/27/2002]
Old Dec 27, 2002 | 10:59 AM
myhatchrips's Avatar
Default Re: Correct Foot Pounds? Help me out? (sgT)
actually its 21 ft lbs for the bigger bolts and 9 lbs for the smaller ones
Old Dec 27, 2002 | 11:06 AM
2muchPSI's Avatar
Default Re: Correct Foot Pounds? Help me out? (myhatchrips)
wtf, now im confused
Old Dec 27, 2002 | 03:53 PM
MattG's Avatar
New User
I'd buy a Helms
Old Dec 28, 2002 | 11:28 PM
Kataku2K3's Avatar
Default Re: Correct Foot Pounds? Help me out? (MattG)
Okay anywhere from 7-10 is good for the 6mm bolts and 18-20 on the 8mm's.. It's not totally crucial that you have them absolutely on (just have them within that range)... Every DOHC VTEC motor I work on gets its 6mm bolts torqued to 9ft/lbs and the 8mm's to 19ft/lbs.. It's worked fine for all the motors that i've ever put together.. You really don't even need to torque the outer 6mm bolts but i always do... Latez
[Modified by JDMspecEG6, 12:29 AM 12/29/2002]
Old Dec 29, 2002 | 12:13 AM
integra6650's Avatar
Default Re: Correct Foot Pounds? Help me out? (JDMspecEG6)
i got 7-10 on small and 20 on larger ones out of haynes
Old Dec 29, 2002 | 09:19 AM
NateTEG95's Avatar
Default Re: Correct Foot Pounds? Help me out? (integra6650)
Right out of the helms manuel. 8mm bolts are 16 lb-ft, 6mm bolts are 8 lb-ft. Also dont forget the order in which you tighten them. Search for the helms manuel I think someone posted the whole thing for the 90-93 teg.
2muchPSI
Feb 6, 2020 06:06 PM
alejandro_da9
Apr 10, 2014 07:37 AM
:::SIRll_EJ1:::
Sep 2, 2009 03:05 AM
DC_RaceR
Feb 14, 2006 04:58 PM
