Valve Guides
Old Dec 25, 2002 | 11:57 AM
fe519's Avatar
Default Valve Guides
I was wondering how to change my valve guides. Is it hard or very simple. I took off my valve cover already... and can someone show me how to do it? Thanks.
Old Dec 25, 2002 | 02:29 PM
Mikey3000's Avatar
Default Re: Valve Guides (fe519)
its hard. you'll need a machine shop or an engine repair shop to do it.
Old Dec 27, 2002 | 06:49 AM
jweller's Avatar
Default Re: Valve Guides (Salvatore Leone)
follow along in your Helms manual.
you do have a Helms don't you....?
Old Dec 27, 2002 | 07:24 AM
SOHCArchangel's Avatar
Default Re: Valve Guides (jweller)
the guides must be pressed in the head?
regardless you cant change them with the head bolted on the block and just the valve cover off
if your going to the trouble to replace the valve guides, might as well do a light rebuild of the head or motor since you are pulling the cyl head off anyway
Old Dec 27, 2002 | 09:55 AM
BoostedH23a1's Avatar
Default Re: Valve Guides (SOHCArchangel)
yea u have to take off the head.. what makes u think u need to replace the guides?
if the valves are alittle loose just ask a machine shop if they can nurle(spellin??) them. that should bring them back into specs.. thats how we did alot of hondas at the machine shop i used to work at..
Old Dec 27, 2002 | 12:50 PM
Ideal's Avatar
Default Re: Valve Guides (BoostedH23a1)
oil leak? get a helms = 80 bucks.
It earns itself back the first time you use it, guaranteed.
dominate9
Apr 14, 2020 02:10 PM
sde780
Mar 30, 2009 03:36 PM
hazrd420
Aug 13, 2007 08:29 PM
S88HON
May 27, 2004 11:48 AM
dizzyroc88
Jan 18, 2004 09:45 AM
