NSX Caliper
where can I buy nsx calipers?
Any of you guys know the dimensions for the nsx rotors, i.e (diameter and width). And are these locking type calipers or floating?
Thanks
Thanks
'91-96 rear: diameter 282 mm, thickness 21 mm new, 19 mm minimum
'97-02 front: diameter 298 mm
'97-02 rear: diameter 303 mm
I don't know the thickness for the '97-02.
i don't know what a "locking" caliper is, but all Hondas (except those with 4 piston calipers) use a floating caliper, the NSX and Legend GS and Pilot/MDX/Ridgeline/CRV ones take a two piston floating, most of the rest use one piston.
The Legend took a 23mm thick rotor, the Legend GS with the 2 piston calipers took a 28mm thick rotor of the same diameter.
97-01 NSX caliper BODIES may be able to bolt onto the S2000 caliper bracket, however they may not, since you may need the 97-01 NSX brackets (not NSX-R brackets) or those from a 01 TL will bolt on. This is meant for a 28mm rotor opposed to your 25mm, but it should be fine.
Or... you could have revived a thread that was more recent (and more on topic) that already had most of the info you shared.
https://honda-tech.com/zerothread?id=1670156
Oh well.
Oh well.
