Honda S2000 Honda S2000
NSX Caliper
Old Dec 25, 2002 | 10:49 AM
hybridturtle's Avatar
Default NSX Caliper
where can I buy nsx calipers?
Any of you guys know the dimensions for the nsx rotors, i.e (diameter and width). And are these locking type calipers or floating?
Thanks
Old Dec 25, 2002 | 12:11 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: NSX Caliper (hybridturtle)
eBay, or the NSX Parts for Sale forum on NSXprime.
'91-96 front: diameter 282 mm, thickness 28 mm new, 26 mm minimum
'91-96 rear: diameter 282 mm, thickness 21 mm new, 19 mm minimum
'97-02 front: diameter 298 mm
'97-02 rear: diameter 303 mm
I don't know the thickness for the '97-02.
Floating.
Old Dec 25, 2002 | 11:51 PM
Default Re: NSX Caliper (nsxtasy)
is it true then that the legend one's are locking type?
Would you know the thickness of the legend rotors?
Old Dec 30, 2006 | 03:09 PM
BrakeExpert's Avatar
i don't know what a "locking" caliper is, but all Hondas (except those with 4 piston calipers) use a floating caliper, the NSX and Legend GS and Pilot/MDX/Ridgeline/CRV ones take a two piston floating, most of the rest use one piston.
The Legend took a 23mm thick rotor, the Legend GS with the 2 piston calipers took a 28mm thick rotor of the same diameter.
97-01 NSX caliper BODIES may be able to bolt onto the S2000 caliper bracket, however they may not, since you may need the 97-01 NSX brackets (not NSX-R brackets) or those from a 01 TL will bolt on. This is meant for a 28mm rotor opposed to your 25mm, but it should be fine.
Old Dec 31, 2006 | 11:23 AM
philadd's Avatar
Default Re: NSX Caliper (Redline57)
Wow, talk about reviving an old thread...
Old Dec 31, 2006 | 01:18 PM
Default Re: NSX Caliper (philadd)
Better than starting a new one, right?
Old Jan 1, 2007 | 04:43 PM
philadd's Avatar
Or... you could have revived a thread that was more recent (and more on topic) that already had most of the info you shared.
https://honda-tech.com/zerothread?id=1670156
Oh well.
Old Jan 1, 2007 | 08:18 PM
Sorry. My thougts were that if someone finds this in the archive, its at least complete, not an unanswered question.
MiamiEgGSr
Jun 4, 2008 12:26 PM
rollercosta123
Jan 11, 2007 04:03 PM
crj_lll
Mar 31, 2005 05:06 AM
AlienKrOZ
Oct 22, 2004 01:40 PM
hybridturtle
Dec 25, 2002 05:20 PM
