Need Help Building My Ignition System for N2o
I'm not sure what to build my ignition setup with, since i'm going to be using a 100shot direct port. What Do you think i should be running? (Timing retard, msd, plugs, plug wires) All that good junk. Nitrous junkies please help!!
we used to use the crane hi6tr unit with adjustable retard back inthe day worked well. Use one step colder plug and factory or NGK wires.
[Modified by b18bturbo, 12:22 PM 12/25/2002]
u just need one thing, msd digital 6..its got all the stuff u need. retard, 2 step...
gotta get a coil w/ it also..hvc or crane version.
ur other option is like a 6a, 6al, sci or whatever basic box. only prob is then u need to buy the n20 retard and all other goodies.
no need for wires.
get a msd cap, digi 6 , and ngk bkr7e and ur set.
merry xmas
no need for wires.
merry xmas
What Do you think of this-- This is what i was planning on running:
MSD Plug Wires, NGK 2 step colder platinum plugs, msd digital 6 as Roby Explained above, and a coil of some brand (prolly msd). Do i need a new cap?
[Modified by integranator, 7:14 PM 12/25/2002]
i thought the 2 steps colder ngk plug was zfr7r (something close to that). I was told that so thats what i got. Actually ngk told me that too, but whats the diff between the b... and the zf....plugs?
son of a bitch thats what people told me to buy!
All this time i thought i had the right plugs, but i guess i didnt. Ill be paying napa a visit soon. Thanks though!
The problem is that there are a lot of people that don't know much about n20. Here's a link from NOS:
http://www.holley.com/HiOctn/TechSer.../NOSTech3.html
It has some good info. Scroll down to the part about spark plugs. I've gone through a melted valve and a melted piston with my nitrous kit. So you could say that I have a little experience with it
However, now that the turbo's going in next spring, the kit will be retired.
[Modified by sando112, 6:43 PM 12/30/2002]
However, now that the turbo's going in next spring, the kit will be retired.[Modified by sando112, 6:43 PM 12/30/2002]
Ive run my nitrous system on my h22a for about 10-15 runs now at a 50hp shot. The plugs look kinda gray...what does that mean? Heard it was normal, but is it detonation?
BTW, what DP system are you using and what fuel upgrades do you have already?
on my set up i ran 100 shot too
i still have the igntion set up for boost now
but my set up works great
MSd dig 6+ with all its features,
msd wires
msd cap
msd blaster ss coil( which was recommended from MSD direct for the digital series igntions)
and a set of NGK bKR7e11 plugs
my set up worked great
msd wires
msd cap
Did anyone check out the new kit from Nitrous Express? It has a fuel rail included with the kit and no solenoid to mount. It looks pretty good.
