Building a custom turbo kit need help?
I was planning on building my own custom turbo kit and but im having drouble finding and picking the right peices.This is what i was gonna build last year.XS engine to4x,xs gtr intercooler,tial 35mm or 40mm wastegate,not sure on the BOV and i have intercooler piping already.Things that i cant really find are d-pipe and manifold,also im not sure what else i would need to complete.PLease anyone and everyone put there imput in.Also you guys with drag cars let me know your setups cause i want to build something like that.Thanks
Visit: http://www.tunertoys.com they build and port match an HF manifold.
Below are a few good links, and from what I hear your stuff will arrive fairly quickly. I also posted this on po.com
Hi guys,
I just thought I'd share this link with those of you that dont know about it.
It is mostly for DSM's but they have a lot of universal parts that we can use to make our own downpipes and whatnot.
http://www.roadraceengineering.com/f...andgaskets.htm
-TIAL 35mm Flange & gasket
-Garrett Oil Drain flange & Gasket
-Garrett T-3 Turbine Housing Inlet Flange & Gasket
-Garrett T-3 Turbine Housing Discharge Flange & Gasket (for making your own DP)
http://www.roadraceengineering.com/exhaustparts.htm
-2.5" & 3.0" cats (Length 16" Cat body size is 12" x 6" x 3 1/2")
**may want to check if they fit**
-Flex Sections (2.5" & 3.0")
-Other Flex Tubes (1.5", 2.5, & 3.0" available by the foot)
**Perfect for WG dump tubes**
http://www.roadraceengineering.com/mandrelbends.htm
-2.5" mandrel bend DP (needs turbine flange and flex pipe)
-various other exhaust and intercooler U-bends (various diameters)
-2.5"-->3.0" reducer
http://www.roadraceengineering.com/hoseandclamps.htm
-Various large hoses:
2.0" to 2.25"
2.0" to 2.5"
2.0" to 3.0"
2.25" to 2.5"
2.25" to 3.0"
2.5" to 3.0"
2.75" to 3.0"
-Silicone Reinforced Hump Hoses
-Various other Silicon hoses
-Various other Nirile hoses (vacuum and boost lines)
-Screw type and T-bolt type clamps (T bolt clamps look heavy duty)
[Modified by BlueShadow, 9:35 AM 12/25/2002]
Hi guys,
2.0" to 2.25"
2.0" to 2.5"
2.0" to 3.0"
2.25" to 2.5"
2.25" to 3.0"
2.5" to 3.0"
2.75" to 3.0"
http://www.jcwhitney.com has awesome prices on mendral bends too
TurboEM1
Nov 11, 2005 10:55 AM
