I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!!
Old Dec 24, 2002 | 07:08 PM
Boostless97Lude
Guest
Posts: n/a
Default I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!!
ok, so i FINALLY get to drive my car today, and i go to my friends house and hang out for a few mintues, but when i go to leave, the car won't start. so here the deal
on my fuel pressure guage on the fuel rail, it read zero
i can't tell if the fuel pump is running
AND
i have a CEL, and it won't show a code, PLUS, i left my Helms at the shop that was doing some of the work.
so, does anyone have any ideas? i have a walbro 255gph fuel pump that is not yet installed, so i am going to put it in tomorrow and see if it solves the problem, but if anyone has any ideas PLEASE PLEASE let me know
Old Dec 25, 2002 | 09:10 AM
SuperSH's Avatar
Default Re: I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!! (Boosted97Lude)
Check the fuel pump fuse and listen when you turn the ignition on for the pump to turn on.
Old Dec 25, 2002 | 09:47 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!! (SuperSH)
ok, so here's the new info..... i just installed the walbro 255gph pump, and from what i've been told you can easily tell if it's running or not from the amount of noise it makes. BUT, i turned the key to position 2, and nothing happened.
like i said, the CEL is on, but it wouldn't flash a code
i checked both fuses for the fuel pump under the dash and they were good
is there some sort of relay that could have went out? if so, where is it located?
Old Dec 25, 2002 | 10:10 AM
prelude1897's Avatar
Did you pull out the little blue connector on the passanger side, stick a paper clip(or small wire) to make the light flash??
Old Dec 25, 2002 | 10:12 AM
Go to http://www.hondaprelude.to/main_checkengine.html
Old Dec 25, 2002 | 12:59 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!! (prelude1897)
i know howo to check an engine code, and the light will not flash
Old Dec 25, 2002 | 02:02 PM
rjr162's Avatar
i know some have relays... if it does it *should*... should.. be somewhere in the area of the fuel pump.. such as near the shock tower or somewhere in there
Old Dec 25, 2002 | 02:26 PM
Mikey3000's Avatar
check your ecu back up fuse (the 7.5 amp under the hood). when mine burned the CEL came on and didn't flash a code.
Old Dec 25, 2002 | 04:36 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!! (Salvatore Leone)
no fuses are bad, i 've checked them all, but is there a fuel pump relay?
Old Dec 25, 2002 | 06:14 PM
Mikey3000's Avatar
yes there is a fuel pump relay. i believe its under the hood in the fuse box.
Old Dec 26, 2002 | 11:34 AM
Boostless97Lude
Guest
Posts: n/a
ok, well, i replaced the relay, the CEL went off, but the car still won't start, my friends at Honda thinks there could be a problem with the immobilizer system, or even the ignition switch (since the 5th gens had a recall on the ignition switch).
fuel pump is new, walbro 255 gph
fuel pump fuses are good
main relay has been replaced
CEL has gone off
still no fuel pressure
Old Dec 26, 2002 | 01:22 PM
fastludeh22's Avatar
why dont you give you fuel pump power manually, then see if it starts, that will narrow down the probs a little.
Old Dec 26, 2002 | 04:02 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!! (fastludeh22)
well, i am having the ignition switch replaced, i had it towed to Honda today.... the immobilizer light wasn't coming on, and the fuel pump wouldn't come on, so the diagnosis was that most likely it was the ignition switch since it hadn't been replaced yet
Old Dec 26, 2002 | 04:21 PM
BoostedH23a1's Avatar
ahah ****** 5th gens..
Old Dec 26, 2002 | 06:25 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!! (BoostedH23a1)
jeezus man.... lets not turn this into another one of THOSE threads......
Old Dec 26, 2002 | 06:55 PM
you know its the truth though...
but for real hope this fixes the prob, if not well go from there.
btw do you have a pic of where in the oil pump you tapped into for the feed line?
ejfromwestbay
Aug 18, 2010 05:44 PM
iNDyCRX
Apr 24, 2008 12:54 PM
dEtSoOb
Jul 12, 2005 06:08 PM
Boostless97Lude
Dec 26, 2002 12:04 PM
Boostless97Lude
Dec 26, 2002 11:33 AM
