JDM ITR header 97 spec
Old Dec 24, 2002 | 05:21 PM
speedevo's Avatar
Default JDM ITR header 97 spec
is the 97 spec 4-2-1? and is it the same as the USDM one?
Old Dec 24, 2002 | 05:39 PM
skafia's Avatar
25 Year Member
Default Re: JDM ITR header 97 spec (speedevo)
It is 4-2-1, and it seems to look like the USDM one, but I highly doubt it.
Old Dec 24, 2002 | 05:41 PM
xjohnx's Avatar
it should be 4-2-1 with a 2.5" collector if it is the same as the CTR's.
I remember reading conflicting information on this though, a couple sources said it was, a couple said it wasn't.
[Modified by xjohnx, 9:42 PM 12/24/2002]
Old Dec 24, 2002 | 06:03 PM
TypeR 599's Avatar
Default Re: JDM ITR header 97 spec (xjohnx)
i have one of those bad boys fs.
Old Dec 24, 2002 | 07:03 PM
R3dL1n3's Avatar
Default Re: JDM ITR header 97 spec (TypeR 599)
it is a 4-2-1 w/ a 2.5" collector(not like usdm). and yes its the same as the CTRs
Old Dec 24, 2002 | 08:48 PM
speedevo's Avatar
Default Re: JDM ITR header 97 spec (R3dL1n3)
so CTR stock header will fit b18 blocks?
Old Dec 24, 2002 | 09:34 PM
Hooch'n's Avatar
yep
Old Dec 25, 2002 | 02:54 AM
madslackin's Avatar
Yes, because the ctr motor (b16b) IS a b18 block. Only b16a blocks are shorter; everything else (b16b, b18a/b/c, b20b/z) is the same.
Justin
951dc5
Mar 21, 2007 10:53 AM
TypeR 599
Oct 6, 2005 03:20 PM
MansuDC2
Jul 26, 2005 03:01 PM
Frito1
Feb 23, 2002 08:10 AM
