**MY HEATER barely blows?!?!****
Old Dec 23, 2002 | 04:42 PM
boostinb18's Avatar
Default **MY HEATER barely blows?!?!****
so this morning i go out to my car and start and let it warm up for a few minutes while im inside getting ready for work and when i go out side i hop in my car and leave my driveway and as im driving i change my heater from defrost to my feet and out of the dash... and the thing is.. it blows relly weak! like when it is all the way up on recirc it usually blows really hard but today, when its all the way up, it feels like it used to when i had it on the first setting i htought the blower wasnt working at all and it was just venting in hot air.. so i pulled the heater blower motor fuse and heater stopped... plugged it back in and the same ****... this is pissing me off cause its cold as F%$K around here ight now!
anyone else ever had this problem or heard of it?? you think the blower motor is bad??
thanks for any help you guys can give me!
boostin
Old Dec 24, 2002 | 03:33 AM
Charlie Moua's Avatar
Default Re: **MY HEATER barely blows?!?!**** (CRXSiBeater)
could be the blower motor resistor
where the heck is that?
i have the same problem also
Old Dec 24, 2002 | 09:29 AM
Drumwurks's Avatar
Default Re: **MY HEATER barely blows?!?!**** (Charlie Moua)
I agree with it sounding like a resistor problem.
I'm pretty sure it's located on or at the motor. (passenger footwell, just above were the carpeting ends) I can't seem to find anything in my Haynes manual (which sucks) on exactly where it is, but it's inline between the heater unit and the motor.
That's about as specific as I can get...
Anyone else know for sure?
Old Dec 24, 2002 | 09:54 AM
Mefain's Avatar
Default Re: **MY HEATER barely blows?!?!**** (Drumwurks)
well actually i had somewhat the same problem in my old 88 Si....cept it blew nothing at all or barely nething at times....but a mechanic friend of mine ran the motor its own source...cause like it was bypassing the stock power and just not working....and its actually located behind the glove box....if you take your glove box down you can easily reach it
Old Dec 24, 2002 | 10:48 AM
Vinceg99's Avatar
Default Re: **MY HEATER barely blows?!?!**** (NjoySleepn)
I think if anything it would be the actual blower motor and not the resistor my resistor was going bad and it wouldnt work on the 1 or 2 settings but worked fine in the other settings and also on recir. and fresh air settings. Also when my was going bad sometimes it wouldnt work at all and I would have to basically hit the bottom of the blower box with a flashlight and it would kick back on. You can see if it is the resistor it is located right behind the glove box (like said above) its a little black rectangular thing with a wire connector going into it. You can usually pick them up from the Honda dealer for like $30 or so bucks....Otherwise try running power leads directly to your blower motor and see if it works better or not.
Old Dec 24, 2002 | 10:50 AM
Lonny's Avatar
It sounds like the resistor. Mine did it last year. Very easy to change if it is like mine.
1. remove glove box.
2. resistor is on top of the blower, remove the two screws and you should be able to tell by looking at it.
3. install new resitor
4. install glovebox.
5. enjoy the heat
Old Dec 24, 2002 | 11:14 AM
C-RICKS's Avatar
Default Re: **MY HEATER barely blows?!?!**** (Lonny)
May you all have a merry Christmas and a happy New Year!!!!
Now lets see if you guys can help me with my problem??
my blower seems to work great!!!!! The problem now is that i have no heat!!!
All my settings seem to work fine except that it's been freakin cold around here and im claustrophoebic wich means i drive with my drver-side window open all the time. So at any given time, all i get is cold air from all directions...
Please help guys..
Thanx in advance for any help you may provide for me !!!!!!
Old Dec 24, 2002 | 11:24 AM
Vinceg99's Avatar
Default Re: **MY HEATER barely blows?!?!**** (C-RICKS)
Please help guys..
I would check and make sure that the valve on the heater hose under the hood opens and closes when you change the temp settings. Also it could be your thermostat. Does your car run cold on the freeway? It could even be your heater core. Check the easy things first and go from there.....Valve, Thermostat...ETC>>>>
Old Dec 24, 2002 | 11:56 AM
Flexmyrex's Avatar
Default Re: **MY HEATER barely blows?!?!**** (Vinceg99)
i agree w vinceg
try opening /closing the valve w your hand on the heater hose, just follow the hose and you will locate the valve by the firewall. i had the same problem, opened the valve and now i got heat
Old Dec 24, 2002 | 12:03 PM
C-RICKS's Avatar
Default Re: **MY HEATER barely blows?!?!**** (flexmyREX)
Well, last week i changed the thermostat hoping that would remedy the problem.
It didn't remedy anything but atleast now i have a new thermostat!!
I guess i'll try opening the valve today after work.. wish me luck!!
If that doesn't work, i'll be asking about the heater core soon..
spock_rocker
Classic Hondas
Feb 29, 2008 04:52 PM
ED6JDM
Oct 15, 2006 06:45 PM
h2392si
Apr 17, 2003 05:11 PM
Sedat1ve
Dec 11, 2002 06:38 PM
Infinity_Racer
Oct 17, 2002 09:37 AM
