its cold as hell....
Old Apr 16, 2003 | 03:55 PM
h2392si's Avatar
Default its cold as hell....
my heater on my car does not want to work, and its starting to get really cold out here sometimes. My A/C works perfect though, nice and cold. the blower motor seems to be working great because it works for everything else like deffoging the window, just the fan and so on. I checked the fuses and im going to check the relay but what could be wrong?? If anyboday has had this problem please let me know how you fixed it. Thanks in advance.
Old Apr 16, 2003 | 05:28 PM
dwn-shift's Avatar
Default Re: its cold as hell.... (h2392si)
All that makes your heat work is coolant flowing through your heater core, and then the blower motor blows air towards the heater core, which heats the air. Check to see if you have coolant. If you do then look under the dash and make sure all linkages are hooked up that opens and closes the door for the blower motor to your heater core.
Old Apr 16, 2003 | 05:30 PM
BerlinaAP2's Avatar
dude we are in CA, there is no need for heaters in this state..
Old Apr 17, 2003 | 12:39 PM
h2392si's Avatar
Default Re: its cold as hell.... (ApexiSi)
where is the heater core? Any other suggestions? Peace out
Old Apr 17, 2003 | 02:11 PM
shming123's Avatar
i have a question, i removed all of my A/C stuff, but now i have no heat! is that supposed to happen?
that A/C radiator thing, was that the heater core? ooops..lol
Old Apr 17, 2003 | 04:16 PM
dwn-shift's Avatar
Default Re: (shming123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2392si &raquo;</TD></TR><TR><TD CLASS="quote">where is the heater core? Any other suggestions? Peace out </TD></TR></TABLE>
Its behind the radio, it kinda looks like a little radiator.
Old Apr 17, 2003 | 05:11 PM
slomofo's Avatar
GDD Member
Thermostat, coolant, or heater core. Hopefully you'll be lucky and it'll be your thermostat.
ExAV8R
Acura TL, RL & ZDX
10
May 9, 2010 10:08 AM
ninjaturtleEG
Jan 15, 2010 11:21 AM
cruleman
Honda Civic (2001 - 2005)
Oct 1, 2006 12:05 PM
type Gendy
21
Oct 6, 2003 02:31 PM
Infinity_Racer
Oct 17, 2002 09:37 AM
