: no heat in the EA... help!! :
memoryFAB.com representative
ive checked the Haynes and redpepper racing however...i went to leave for work today.. a brisk 20 degrees.. let the car warm up and i have no air..warm or cold coming from the vents. i checked all the fuses under the dash and they appear to be fine, and still nothing. the sun is shining so its not that bad however i need to get this problem solved asap before it gets to cold and or icey.. thanxx for your help!
Re: : no heat in the EA... help!! : (spock_rocker)
test blower motor to see if it has power at all speeds before buying one because it could be the blower resister.
Re: : no heat in the EA... help!! : (8907si)
yea oddly enough when leaving this evening.. it worked just fine! damned old cars!
Screw you guys, I'm... going... home.
Make sure that the drain for the blower motor is clear. If it isn't then in freezing weather it can lock the fan in a block of ice, and as it thaws in the sun during the day it will release it. The drain tube sticks thru the passenger side firewall and bends downward.
Re: : no heat in the EA... help!! : (tjbizzo)
could still be the resister. when electrical components heat and cool they can do fun things if they are on there way out.. i had my main fuel relay go out sporadically on my EF and EA.. fun..
Re: : no heat in the EA... help!! : (E-AT_me)
its been ok sense.. but fuel in the EA..*sigh* my gas tank was rusted from the inside(no bladder like newer models) which clogged my lines, filter and injectors! that was fun to replace!
BrenaNickels
08-24-2008 06:10 PM
boostinb18
12-24-2002 12:03 PM
