99accord ex v6 egr fix
Old Dec 23, 2002 | 05:48 AM
Lip's Avatar
Lip
Default 99accord ex v6 egr fix
check enging light came on. ran a code. egr valve clogged. problem is....honda sucks nuts and won't cover the TSB because it ends at 80k miles and i have 83k.
anyone DIY? Where is it? right near TB just below it? I haven't even looked yet. How did you clean it out etc.
tia
Old Dec 23, 2002 | 02:12 PM
Chiovnidca's Avatar
Default Re: 99accord ex v6 egr fix (Lip)
The best way would be to remove the intake manifold and clean out the EGR port. If it was mine I would drill it out to about 1/2".
Old Dec 23, 2002 | 08:10 PM
jweller's Avatar
Default Re: 99accord ex v6 egr fix (Chiovnidca)
OK, now why? is there a performance gain? do you think it is poorly designed? is this on the V6 only?
Old Dec 24, 2002 | 02:59 AM
Chiovnidca's Avatar
Default Re: 99accord ex v6 egr fix (jweller)
By drilling it out, you mean. Yes, I think they are poorly designed, and I would guess Honda thinks so too since they have us drill them out. (Per service bullitin #99-085.)
Old Dec 24, 2002 | 04:17 AM
Lip's Avatar
Lip
sounds fine to me. any way of tricking the ecu not to throw the code? or will the ecu not care how big its ported...just that its not clogged
Old Dec 24, 2002 | 08:51 AM
Chiovnidca's Avatar
Drilling it out keeps it from clogging up as fast. The EGR valve controls the amount of flow.
Old Dec 26, 2002 | 04:51 AM
Lip's Avatar
Lip
Since i'm not sure if your joking on the size. were you serious about the half inch porting? Until i visually look at it.....i'm not familiar with its current size
btw. thanks for the help
Old Dec 26, 2002 | 12:26 PM
Chiovnidca's Avatar
Yea, some of us drilled them out to 1/2 inch before the bullitin came out. You have to be sure to follow the same angle as the original hole though. I don't know how much extra meat there is. It's original size is about 8mm.
Old Dec 26, 2002 | 07:34 PM
Nick M's Avatar
Jeff -
I know with 5th gen accords you can use a thin sheet of metal over the EGR and it will trick the ECU into thinking the ECU is functioning fine. Several guys in this forum have done it. I havent. Hopefully tomorrow when more people get back to work you can get a more specific answer. The sheet of metal over the EGR is an old muscle car trick.
Old Dec 27, 2002 | 03:26 AM
Chiovnidca's Avatar
Default Re: 99accord ex v6 egr fix (Nick M)
That wont work on a 6th gen. The ECU checks for EGR flow by watching the MAP sensor voltage. It would be kind of hard to fake that.
Old Dec 27, 2002 | 04:33 AM
Lip's Avatar
Lip
very much appreciated guys
Old Dec 27, 2002 | 04:54 AM
Nick M's Avatar
Well there you go. lol
Old Dec 30, 2002 | 10:15 AM
Lip's Avatar
Lip
thanks. you helped alot. I'll get cracking on that manifold
arielb1
Apr 15, 2016 03:20 AM
KaliMist
May 19, 2014 01:55 PM
jdenman03
Honda Civic (2001 - 2005)
May 9, 2011 08:02 AM
jose310
Jan 8, 2009 09:35 AM
DirtyMormon
Jan 10, 2008 05:00 PM
