"theoldone.com"s fuel pressure mod...
I did this mod, and it worked, got my fuel pressure down to 40 psi. But no, it's hard to start sometimes. Am I correct in assuming that it is because the regulator cannot hold the pressure,because of the hole, after the car sits for a while? Or does anyone else have this problem?
thats normal....i did that mod awhile ago, but eventually got nervous that it wasn't hold enough pressure at full boost so i upgrade to the AEM fpr
No people just don't like to be proven wrong. They're not a scam. Bad threads inccur because people are unwilling to except the truth. Evolution is 2 steps forward 1 1/2 back. People used to say the earth was flat even after Columbus proved them wrong. When idiots are amuck the truth is always twisted.
Trust me Larry knows what he's talking about even though it does seem like crazy-man bantering.
If you have problems starting you should turn the key on and let the fuel pressure build up before starting it.
[Modified by tzsir, 5:52 AM 12/23/2002]
Trust me Larry knows what he's talking about even though it does seem like crazy-man bantering.If you have problems starting you should turn the key on and let the fuel pressure build up before starting it.
Larry knows his **** .
Larry is also a LIAR and a *******.
He couldn't cover his lies anymore and had to shut down his bbs.
It work's to lower the pressure while the engine is running. Once the engine turns off, some of the gas drains out of the rail and pressure drops. I usually turn the key on and off a couple of times (don't crank the engine over).
back to the topic
turn key to run, count 1-2, then turn to start..........
VRRRM!!!!!!!
Did I mention the car had been sitting for almost 3 months?????
Gotta love fuel injection!
VRRRM!!!!!!!
I just did this recently, but haven't had any problems starting the car. Like the others have said, turn the key, the check engine light will come on while the fuel pump primes. When the check engine light goes out, crank it over. My B&M fuel pressure gauge is on its way, so I have no idea where my pressure is though. I've heard of people having problems with the AEM FPR, so I have no idea what to do if this doesn't hold up. Aeromotive?
i did this mod and hated how my car started, even with letting the pump build pressure, it cant be good for a starter to crank like that all the time. I went back to stck with a B&M chop top and lowered the pressure enough that way.
danno33
Dec 27, 2006 02:16 PM
technine
Mar 4, 2003 12:03 PM
