CTR cams vs. ITR cams
I tried the search but it mainly came up with "classifieds". What are the specs on the CTR cams vs. the ITR cams and are they worth the $ to switch? Anyone have dyno plots with the two different set-ups? Is there a difference when it comes to the changeover?
Thanks guys and gals!
(Mine's a '98)
[Modified by Rwecked, 7:00 PM 12/22/2002]
(Mine's a '98)
arent the 00-01 ITR cams the Same as the CTR cams?
good lord... this has been covered 43095782309485720395 times...
CTR cam is more aggressive (intake)... Exhaust are the same...
00+ ITR Cam (Intake) is the same as CTR...
EDIT: typo..
[Modified by v, 9:56 PM 12/22/2002]
EDIT: typo..
intake/exhaust, which the **** is it....
anyhow....i wouldnt recommend CTR cams to any itr owner.
Guest
Posts: n/a
jun vs toda can not be determined due to diffrent circumstances such as tuning.
itb's w/ JUN cams are fine.
highest horsepower(street header) was the hytech unit.
ITB's well cut your gas milage in half as they are not built for street use.
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
he's right, the CTR intake cam is almost certainly physically identical to the '00+ ITR intake cam. the '98 and '00+ ITR exhuast cams are the exact same, however.
CTR cam has like .1 or .01 more duaration, which makes a a lil better than the 00+ itr cam.
If they are different, they are still so close it doesnt even matter. IMHO, not worth changing a 98 R spec cam to a 00Spec, just get Toda A's or something with a little more oomph.
Just to add to the Upgrade to Toda or JUN camp . . . . Upgrading is good but, After buying the 00/01 cam for $290 (New) and selling my 98 Cam for $200 I paid $90 for 6 whp. Toda A's even if you got $300-$400 for your stock cams would cost $500+ so $/hp it isn't a bad idea.
smkngsr
10
May 2, 2005 01:25 PM
1GreyTeg
Aug 26, 2001 10:20 AM
