Rubbing sound when driving
Old Dec 21, 2002 | 03:59 PM
Dd95Gsr's Avatar
Default Rubbing sound when driving
I put on new rims and tires yesterday and now when i drive it sounds like a metal rubbing sound on the front right. could it be my brakes?
Old Dec 21, 2002 | 04:00 PM
ucb's Avatar
ucb
Default Re: Rubbing sound when driving (Dd95Gsr)
maybe the tires/rims are too wide and rubbing on your springs
Old Dec 21, 2002 | 04:47 PM
Dd95Gsr's Avatar
Default Re: Rubbing sound when driving (UCBgsR)
nah, its only one tire and its the same size as my last. hmm........
Old Dec 21, 2002 | 07:15 PM
fstgsr's Avatar
Which wheel is rubbing?
Old Dec 21, 2002 | 10:34 PM
Dd95Gsr's Avatar
Default Re: Rubbing sound when driving (fstgsr)
the front right. like itll stop sometimes but then start again. gets faster when speed increases and really slow at like 5mph
Old Dec 21, 2002 | 10:57 PM
ucb's Avatar
ucb
pull off that rim and see if there is any wear on any of the components. if it increases with speed, it can only be something rotating.
Old Dec 22, 2002 | 08:59 AM
Dd95Gsr's Avatar
well i talked ot the guy who helped me and he said the original rim and tire fell off half way and was hanging there when we jacked up the car (he loosed the lugs while the car was on the ground so it didnt rotate) ill pull it off oon and see what the deal is. could that have made something worng?
Old Dec 25, 2002 | 11:25 PM
Dd95Gsr's Avatar
wow this sound is getting worse everytime i go somewhere. really loud and screechy now. i have no clue what to look for when i take off the rim. any help?
Old Dec 26, 2002 | 02:17 AM
IntEGNYC's Avatar
the rim and tire (the wheel) fell off half way?
he loosed the lugs while the car was on the ground so it didnt rotate?
not quite sure what you did or how you did it. sounds like there's damage to the wheel. with your description, its hard to tell what was done. sorry...
I wouldnt drive that car until you have that wheel examined. you may cause more damage if you ride on it further.
Old Dec 26, 2002 | 11:16 AM
TRE_'s Avatar
Sometimes small rocks and cinders can get behind a brake dust gaurd. That happenend to me and i just took the wheel off and blew out the brake and sure enough a little pebble fell out. Sorry if that doesn't help.
ninjadancer
11
Oct 15, 2009 03:18 PM
pearlteg
Aug 26, 2005 12:01 AM
BrandonClaps
Apr 11, 2005 03:19 AM
AznBlueBoy
Jan 14, 2005 03:10 AM
BoostedH23a1
Oct 20, 2003 07:41 AM
