92-95 suspension on a 89 si?
Old Dec 20, 2002 | 08:26 PM
turbo sol's Avatar
Default 92-95 suspension on a 89 si?
i have tokico blue shocks and H&R sport springs on my del sol, i think i can swap them over to my new crx.
any thoughts? will it work?
Old Dec 20, 2002 | 08:44 PM
wronghand's Avatar
Default Re: 92-95 suspension on a 89 si? (turbo sol)
The rears should work fine. The fronts will require changing the front forks to the 92-95's. Please someone verify this. It is late and I am tired.
Old Dec 20, 2002 | 09:34 PM
brian g's Avatar
The 92-95 stuff is too tall.
brian g
Old Dec 21, 2002 | 09:49 AM
turbo sol's Avatar
Default Re: 92-95 suspension on a 89 si? (brian g)
i just checked the web site and they do have different parts numbers for the crx and del sol.
oh well. cant say i didnt try.
Old Dec 21, 2002 | 10:25 AM
714phil's Avatar
you have to change the forks in the front. i have teins for an EG6 on my 91 STD.. of course i had to change the rears to 88's. and yeah they are too tall like said above.. but to answer your question.. if you change thefront forks, the suspension will work.
Old Dec 21, 2002 | 01:54 PM
IamVtec's Avatar
The setup will work aslong as you use the 92-95 front fork for the front. And the rear should work just fine.
I got rear EG suspension on mines.
Old Dec 21, 2002 | 03:08 PM
turbo sol's Avatar
Default Re: 92-95 suspension on a 89 si? (crx dragga)
if they are too long, will it even lower the car?
i amsure i can pick up a set of lower forks for chgeap at he junk yard.
Old Dec 21, 2002 | 05:01 PM
philly-O's Avatar
you might even have to notch your control arms, but they will fit.
TRYLSTEG808
Jan 5, 2008 12:11 AM
ProjektSol
22
Jul 17, 2006 10:35 PM
slackura
May 24, 2006 03:27 PM
93EH6
13
Jan 1, 2003 12:36 AM
marty
11
Jan 3, 2002 04:50 PM
