Delsol suspension question
Old 05-24-2006, 01:07 PM
slackura's Avatar
Default Delsol suspension question
ok I have a 95 del sol si VTEC model
my question is, what types of civic lowering springs will fit on my car, are 88-00 civic springs all universal to my car or is it only the 92-95 generation
thanks for your help!
Old 05-24-2006, 02:11 PM
slackura's Avatar
bump.. someone must know this
Old 05-24-2006, 02:33 PM
skip.two's Avatar
Default Re: Delsol suspension question (slackura)
yes, 88-00 Civic springs will fit on the Del Sol.
92-95 Civic's have the same suspension as the Del Sol
94-01 Integra's (excluding Type R) suspension are interchangeable with the 92-95 Civic/93-97 Del Sol.
and use the <u><FONT COLOR="red">Search</FONT></u> function next time.
Old 05-24-2006, 03:27 PM
MonkeyBoy668's Avatar
Default Re: Delsol suspension question (skip.two)
Technically ITR components can also be used since the geometries are the same.
The biggest difference (that I've seen at least) is the rear LCAs, in the ITR they're of a different design than the stock Del Sol LCAs. In the Del Sol the shock splits & goes around the rear LCA, in the ITR the rear LCA splits and goes around the shock.
If you use rear ITR-style shocks AND replace the rear LCAs with units from an ITR, then you can use ITR components on a Del Sol. But I wouldn't recommend going the ITR route unless you want a particular coilover setup that isn't available in a Del Sol compatible form - there's not much to gain for that extra cash (the ITR LCAs are lighter but pfft).
starcraftbw
Suspension & Brakes
08-22-2007 12:32 PM
DaveyDelSol
07-24-2006 04:06 PM
707EF8
Suspension & Brakes
07-22-2006 12:22 PM
2K4K20
08-14-2005 05:47 PM
Del_Sol_s
07-22-2005 09:24 AM
Quick Reply: Delsol suspension question
