N A car leans out in 4th and 5th gear when vtec engages
Old Dec 20, 2002 | 01:45 PM
TurboBumblBee's Avatar
Default N A car leans out in 4th and 5th gear when vtec engages
the code it is throwing casue of this is code 10 the air intake temp sensor but i have replaced it once already so i dont think it is bad what else could be casueing this could my timing be causing this any input will help thank you the motor is a b18c w/ i/h/e/im/& tuned vafc
[Modified by 95CivicEX, 6:03 PM 12/20/2002]
Old Dec 20, 2002 | 04:25 PM
tegasaurus's Avatar
Default Re: N A car leans out in 4th and 5th gear when vtec engages (95CivicEX)
if it leans out and you have a vtec controller... im guessing you changed your VTEC point. If you did this, were you sure to properly increase the fuel? I'm guessing you did not, that is why you are leaning out.
zenon8890
Apr 18, 2008 12:57 PM
TheAccordGuy
May 23, 2006 04:41 PM
JDMlyfestyle
May 14, 2004 03:32 PM
jonas
Mar 15, 2003 03:09 PM
MyWhiteCivic
Sep 29, 2002 11:29 AM
