Check engine light came on, then car won't start ?
Ok I will not boar you guys with a long story, I come out from Pepboys, start my car and the check engine light comes on. So I check the ecu, the light is just on, no blinks, nothing. So I am like thats odd, I turned off the car hoping the check engine light would go off. Well my car cranked but would not turn over. I sat there thinking what it was, I did not leave anything on, I did not turn my radio off but it shuts off when the car is off , I don't think this had anything to do with it. I was only in there for 5 minutes so its not like I was in there long. So I try to start it up, and it starts right up with no problems. So what was it ?
[Modified by 90blackcrx, 10:42 PM 12/20/2002]
Does it do this only while it's hot or cold?
It could be a crank position sensor issue... or whatever you call the equivalent on the honda motor.
It is cold out, but it never did this before. It did along time ago with my old engine in. And the only thing I did different then normally was hold the brake while I started it.
[Modified by 90blackcrx, 12:58 AM 12/21/2002]
sianzsianz
Jul 12, 2006 07:20 AM
918-Hatch
May 20, 2004 09:44 PM
goldievt
Aug 11, 2002 04:52 PM
