Problems with ABS. Should I get it fixed?
Alright, I bought my car 2 yrs ago with problems with abs (never worked). When I slam on the brake, the brakes just lock up. I've been driving like this and it's not a problem, only when i slam the brakes. Now, the abs light turns on, and the electrical power seems to go weak. Then it turns off, and everything is fine. Should I get it fixed? How much am I looking to spend?
i am having the same problem as u. when i start my car, the abs module or whatever u call it in the front left when u are looking at the engine makes a loud buzzing noise, when it stops buzzing, the abs light goes on. i had a shop look at it and they just filled that resevoir w/ fluid. that worked for about a week, then the light kept coming on. i'm not sure what to do either, if it costs an arm and a leg, i can live without the abs, but the light sure is damn annoying. later
just a random question about ABS. Why do people dis-arm their abs for the winter... is it easier to slow down without ABS than with ABS in snow or something?
-Ryan
-Ryan
exactly papagoodgsr, that stupid noise always goes on after on turn my car. yeah i can live without too. if it was cheap, i would fix, but it's gonna cost a grip, forget about it. does anyone know how much that would cost to fix it?
hey same thing happens to me too. about 3 months ago the ABS light started coming on. got to a point when i turn my car on i hear the ABS motor running then it shuts off then the light goes on. i filled up the ABS resorvoir and it kinda fixed the problem for a lil bit.. but now if im driving for a long time.. like 30 minutes.. the ABS light will come on. but if its for short distances it won't go on. dunno what i should do... cuz if i bring it in to a shop they'll say they won't be able to duplicate the problem, unless i drive it for a long time before i bring it in so the light can come on...
My abs system went recently too. I turn on the car, and there is a whining noise for a minute or so and then the abs light goes on and I have no abs. I think it is the accumulator pump, but I'm thinking I might have it checked out.
Anyway, you can buy a used one, but who knows how long a used one will last. If you put on in from a newer integra, you'll have to redo all the lines. Ditto if you remove it... from what I understand. Just pull the fuse just in case it decides to kick in unexpectly when driving. This happened to a friend of a friend in his Prelude.
I just went to my mechanic, and he said everything is coo. The abs won't be a problem. just a fyi with you with the same problems.
when i start my car, the abs module or whatever u call it in the front left when u are looking at the engine makes a loud buzzing noise, when it stops buzzing, the abs light goes on. i had a shop look at it and they just filled that resevoir w/ fluid. that worked for about a week, then the light kept coming on. i'm not sure what to do either, if it costs an arm and a leg,...
Here is a diagram of the '94-'97 Integra ABS module:
This reason that I know about this is because the O-ring on my '94 GS-R failed after about 1 year and it was replaced under warranty. My wifes '96 Honda Odyssey also has the same ABS system and it's ABS light came on and I recently replaced the failed O-ring (which cost me ~$1.50 at my local Honda dealership).
ramz7887
Mar 22, 2007 07:51 PM
