vtec problem
Old Dec 19, 2002 | 09:05 PM
typeR00-0005's Avatar
Default vtec problem
when i'm in first gear and i hit vtec sometimes vtec won't engage. i have the vafc
engage at 5500. and then sometimes vtec will engage at 6500. and another time it engaged at 7000.it's only in first gear every other gear is fine.do you think it's the vafc connections to ecu.and also my check engine light is on it's because i have a test pipe and the o2 sensor is throwing a code. i don't know if that is the problem.could it also be oil level.thanks for any help guys.
Old Dec 19, 2002 | 09:15 PM
Lude Vtec 94's Avatar
Default Re: vtec problem (typeR00-0005)
Dont know albert
Old Dec 19, 2002 | 09:16 PM
Default Re: vtec problem (Lude Vtec 94)
what's up
Old Dec 20, 2002 | 12:07 AM
TypeR 599's Avatar
it probably is your oil level. check it, it'll take 5 seconds.
Old Dec 20, 2002 | 01:14 AM
EK MONEY's Avatar
Default Re: vtec problem (TypeR 599)
check connections and oil level.
Old Dec 20, 2002 | 09:23 PM
Default Re: vtec problem (Peagreenhatch)
thanks guys
Old Dec 20, 2002 | 09:29 PM
Gong Show's Avatar
Same thing happened to me before, and my problem was oil level.
Old Dec 20, 2002 | 09:43 PM
sslude's Avatar
Default Re: vtec problem (GONG SHOW)
have you recently changed your octane level in gas? make sure and check all connection.
typeR564
Apr 23, 2006 05:10 PM
2k1 GSR
Mar 14, 2005 10:39 AM
EsQueue
May 1, 2004 09:15 AM
DocV
Jan 10, 2003 05:52 PM
95 GSR B20VTEC
Jul 25, 2002 01:08 PM
