flat top or domed pistons to make high comp raito
Old Dec 19, 2002 | 05:05 PM
I_know's Avatar
Default flat top or domed pistons to make high comp raito
Ok, I'm making a certain CR for the motor and wonder if it would be wiser to make the numbers with the cc's from the piston, or concentrate on a smaller headgasket with flat tops
I really wanna use dome pistons to keep a thick headgasket, is that a smart idea or not
Old Dec 19, 2002 | 06:07 PM
Mr. Vapor's Avatar
Default Re: flat top or domed pistons to make high comp raito (I_know)
flat tops will yield lower compression then a dome top. and a dished or recessed will be even lower then a flat top. you dont want a dome, thats for N/A usually
Old Dec 19, 2002 | 08:27 PM
Pelican's Avatar
Default Re: flat top or domed pistons to make high comp raito (NYb16)
I think what he's saying is...Acheiving the SAME compression ratio, which would be better? Flat-top or domed
like huge Headgasket with domed
or thin headgasket, milled head with Flattops
Old Dec 19, 2002 | 09:07 PM
tony1's Avatar
Default Re: flat top or domed pistons to make high comp raito (Pelican)
Flat top or dished pistons are best for combustion efficiency. Go with the lower compression pistons and stock headgasket.
Old Dec 21, 2002 | 07:07 AM
QCKGSR's Avatar
Default Re: flat top or domed pistons to make high comp raito (tony1)
go with a flat top piston, if you need compression mill the head, a smaller combustion chamber will be more efficient to an extent...
dc2-millano-red
14
Jan 1, 2014 05:48 AM
HellaFab
11
Jul 13, 2011 11:51 PM
VVENOM800TT
Feb 17, 2011 02:48 PM
TypeR0wnz
Feb 20, 2003 09:52 PM
MOTOR R
Nov 26, 2001 03:29 PM
