car makes noise when i turn
Old Dec 19, 2002 | 04:56 PM
ahead's Avatar
Default car makes noise when i turn
hey guys, ive got a 98 gsr and i took the power steering belt off about 3 or 4 months ago (im posting in here cause i know you guys disconnect your p/s more than the regular integra guys). my car never made any noise when i was turning or anything for awhile, then i got into a really small accident, i wasnt even going over 5mph but there was a decent amount of body damage cause my cars lowerd and it went under the other car when i rear ended him. basicaly my problem is this, after i got the car back from the shop i noticed a few days later that when im not moving too fast and i turn the wheel the car will make these noises, almost like i guess you could say a humming noise, i can feel it through the wheel too. what do you guys think it is? you think if i put the belt back on it will go away? should i flush out the p/s fluid and put some more in? any help will be aprecaited. sorry for the long post, and thanks in advance
Old Dec 19, 2002 | 05:17 PM
PYITR821's Avatar
Default Re: car makes noise when i turn (ahead)
I used to have a 99 Gsr and I remember it made the noise you are talking about after about a year of owning it, and it had the power steering. I took it to the Acura dealer because it was still under warranty and they told me others had the same problem. He said that they didn't put enough grease at the lower part of the steering column from the factory, so after awhile it would dry up and start making noises when you turn the wheel. They just put more grease at the base of the steering column and that was it. The noise went away for awhile but It came back later on.
Old Dec 19, 2002 | 05:20 PM
ahead's Avatar
Default Re: car makes noise when i turn (PYITR821)
what kind of grease did he put, or what kind should i use? and which part of the steering column, can i reach it from inside my car? thanks alot
Old Dec 19, 2002 | 05:33 PM
PYITR821's Avatar
yeah, you do it from the inside of the car. I guess you just put some grease at the base of the steering column. Not sure what kind of grease though.
[Modified by PYITR821, 6:35 PM 12/19/2002]
Old Dec 19, 2002 | 05:55 PM
vtec.dc2's Avatar
https://honda-tech.com/zerothread?id=351057
Old Dec 19, 2002 | 06:05 PM
ahead's Avatar
Default Re: car makes noise when i turn (vtec.dc2)
Probable cause: Not enough grease between the pinion shaft and the grommet.
Corrective action: Apply DC111 between pinion shaft and grommet.
1. Remove steering joint cover
2. Use small screwdriver to insert the grease between the pinion shaft and the grommet.
3. Reinstall joint cover.
4. Turn steering wheel to verify that the squeak is gone.
i got that from the thread that was posted for me to look at. you guys think thats what ive got to do to get rid of this noise? one last question, could you guys tell me where the steering joint cover is located? if someone could take a pic and post it id really apreciate it. thanks for all the help
Old Dec 19, 2002 | 06:55 PM
vtec.dc2's Avatar
page 17-19 and 17-32 - helms manual - doesn't mention anything about greasing that part(s)
if no helms manual, this might give an idea
http://www.acuraautomotiveparts.net/...TEERING+COLUMN - somewhat shows assembly behind the pedals, - below #6
http://www.acuraautomotiveparts.net/...=P.S.+GEAR+BOX - around item #8
Old Dec 19, 2002 | 07:02 PM
ahead's Avatar
thanks alot guys anyone have any idea what kind of grease i should use for this? thanks for all the help
Old Dec 19, 2002 | 07:10 PM
vtec.dc2's Avatar
as far as instructions, i'm just estimating on where it would be from above description, if anyone knows for sure, please reply.
Old Dec 19, 2002 | 07:12 PM
ahead's Avatar
oh i looked right past that, thanks. and is this a common problem on integras, have you guys heard about it happening before or is it more on the rare side. thanks
Old Dec 19, 2002 | 11:09 PM
PYITR821's Avatar
From what the dealer told me there were alot of other integras with the same problem. I don't think it is a common problem, just on some of the newer integras.
Old Sep 25, 2008 | 12:08 PM
TiGASNANGULO's Avatar
good info
...rohit
Sep 3, 2007 03:10 PM
...rohit
Sep 3, 2007 11:19 AM
mfarzin
Nov 8, 2006 09:56 AM
poisonko
Jan 15, 2006 12:30 PM
Ben-VTEC
Apr 10, 2003 05:03 PM
