battery questions
Old Dec 19, 2002 | 12:34 PM
preluder's Avatar
Default battery questions
okay question alright i have a hard problem starting my car when its cold ,on the other hand when it starts when four hours pass the car is hard to start again its my battery thats the problem right? if someone gives me a boost i can charge my battery up again right for about a goos ten minutes rightg my battery is a diehard so after givin it a good boost i should have no problems right?
Old Dec 19, 2002 | 12:56 PM
Starrman85's Avatar
Default Re: battery questions (preluder)
wth did u just say? i dont quite understand wat ur saying. use complete sentences
Old Dec 19, 2002 | 12:59 PM
preluder's Avatar
Default Re: battery questions (STARRMAN85)
okay my car is hard to start when it i leave it off to go to work in the morning when i get it started is okay to drive then but each and every morning its hard to start it struggles a bit could it be a discharged battery could i just get a boost and make it better or should i get another batter?
Old Dec 19, 2002 | 01:03 PM
Starrman85's Avatar
i'm no car expert, but i kno engines work harder when its cold, cuz the engine is cold, and the oil and such is really thick, but i'm not really sure. could be ur battery.
Old Dec 19, 2002 | 01:11 PM
preluder's Avatar
yo you got a 92 accord right 2door or 4 door? what else u got on yours?
Old Dec 19, 2002 | 05:12 PM
Guru's Avatar
Default Re: battery questions (onetym408)
Sounds like you need a bettery warmer to help with that chemical reaction... Discount Auto is the place to go.
Old Dec 19, 2002 | 08:46 PM
Starrman85's Avatar
Default Re: battery questions (Guru)
Preluder:
i'm guessing ur talkin to me . i have a 2dr white accord EX. all i have done is wats in my signature right now. on the to do list is rims and exhaust. i'm lookin at gettin the Motegi MR7's in 17". anywayz, catch u later.
[Modified by STARRMAN85, 10:16 PM 12/19/2002]
Old Dec 20, 2002 | 07:41 AM
preluder's Avatar
with all the thinkgs thats on my car now will it be a problem if i have a bottle warmer in my car ,does it really drain the battery ive heard a rumor from my homeboy who told me that . die hard makes a good batter and i have a diehard gold left the door open alot when i thought it was an in and out job when it came to installin **** or so i though i had my dads car give me a boost for a half an hour the problem with startin the car only got a little better. what shold i do just get another battery right?
Old Dec 20, 2002 | 07:47 AM
4doorH22's Avatar
The battery may be okay and the problem may be elsewhere. I dunno I'm having a very hard time reading your sentences for some reason.
Old Dec 20, 2002 | 08:26 AM
cyrixvsp2's Avatar
Default Re: battery questions (4doorH22)
i have a hard time reading these sentences also but here's what i think:
It could be a crappy battery OR your alternator could be dying and not fully charging your battery. Before jumping to those things, first check all the connections on the battery and alternator to make sure that is good. Sometimes a loose wire can jack things up and not charge the battery. Those battery warmers are a bunch of poopoo. In the winter here it frequently gets in the negatives and i have no troubles. The tranny fluid and all is thicker but i don't have problems with starting, batteries work just fine without a warmer.
You can take your car to a local autozone, they do free battery testing. That will tell you if your battery is going or if the battery is fine then the alternator isn't doing it's job.
Old Dec 21, 2002 | 07:03 AM
preluder's Avatar
Default Re: battery questions (cyrixvsp2)
i found out what was wrong everyone it was the battery guys it was crazy tryin to figure that **** out . but they put it on the tester diehard gold and the indicator said it was bad price 3 year warrantee 80 bucks. also one question how many people you know have done their rpm tachs by themselves here?
Old Dec 21, 2002 | 11:18 AM
cyrixvsp2's Avatar
umm...why do you need another tach?
Old Dec 21, 2002 | 03:28 PM
Peter Griffen
Guest
Posts: n/a
Me too. It's difficult to understand but I'm gonna say get an Optima red top.
Problem solved. The winter really saps the batts.
Old Dec 21, 2002 | 03:53 PM
preluder's Avatar
Default Re: battery questions (Peter Parker)
the reason why i need another tach is to look cool while im drivin it turns colors when you are driving and all thats why i like pro-guage and all. hey anyone know of a good site to watch a video of a honda accord with a prelude engine in action?
Cause i just wanna see what i will look forward to having in the summer a prelude engine inside my 92 accord?
Old Dec 21, 2002 | 06:58 PM
cyrixvsp2's Avatar
well, ok, i guess if you want a huge ugly pointless tach on your dash then go ahead.
about the prelude motor in accord video. It will look the same. tehy don't do anything special but drive. It'll look the same as an accord with 200hp accord motor.
Old Dec 22, 2002 | 12:50 AM
preluder's Avatar
can you tell me at least which site to go to i really wanna see whats its like. I went to h22a.org and the **** wont even play right. any suggestionjs and no my tach isnt ugly what you got in your car?
Old Dec 22, 2002 | 11:56 AM
cyrixvsp2's Avatar
i definately don't have a huge tach sitting on my dash as an eyesore. not needed so i don't have it.
and i don't know where you would find videos. umm... try http://www.hondaswap.com
http://www.accordinglydone.com
http://www.clubsi.com
they might know.
Old Dec 22, 2002 | 01:26 PM
4doorH22's Avatar
Here's me doing zero to 67 with a grandma street start. It's real dark gotta turn up the contrast all the way. 0to67.avi
hondacharged
Oct 17, 2008 02:02 PM
W O T
May 8, 2007 11:38 PM
W O T
May 8, 2007 10:36 AM
Zulu888
May 26, 2006 09:14 AM
B18C-RnVA
Nov 7, 2002 04:44 PM
