Civic trunk leak -help please!
Old Dec 19, 2002 | 09:55 AM
grundy's Avatar
Default Civic trunk leak -help please!
I have a 1991 Honda Civic Hatchback - running strong with 185,000 on it. The problem is that I get water leaking into the trunk area when it rains - which it does quite a lot here in NorCal.
Last year I thought that I had the problem solved. The rain gutters drain onto the tops of the taillight assemblies - the taillights were filling up with water and leaking into the trunk. After failing to keep the water out, I simply drilled drainholes in the taillights assemblies and had no more problems.
We just had our first serious rain here, and the trunk is once again full of water - seems to be isolated to the right side. I don't think it came through the taillights, but I can't figure out where the water has come from.
Any suggestions on what might be the source of the leak?
Old Dec 19, 2002 | 01:01 PM
keithv's Avatar
Default Re: Civic trunk leak -help please! (grundy)
we just had 2 recent posts on this exact subject.
https://honda-tech.com/zerothread?id=362617
https://honda-tech.com/zerothread?id=361999
as the rules state, plese try the search next time as you will probably get more results from that than you will from just this one post. if you have questions on how to use the search, email me (since you can't use the IM feature yet).
beat
Jun 11, 2014 11:04 AM
meeka
Dec 29, 2012 07:51 PM
91EFCIVICII
Feb 28, 2011 11:56 AM
jaebekae
Feb 27, 2010 02:02 PM
joemeshuggah
Jan 16, 2005 10:44 AM
