slightly rough idle problem
Old Dec 19, 2002 | 05:40 AM
shahram72's Avatar
Default slightly rough idle problem
Hello all, newbie here. I'm new to this site but not car forums. I've just never needed Honda assistance before. I hope this the right forum. My car is a 1997 Civic with Automatic. At 50K I replaced spark plugs with Bosch Platinum tip. A few months later a rough idle developed(I don't know if it was the plugs) and the check engine light came on. Went to Autozone and they put their code reader on it. It was reading the O2 sensor. So I replaced that with a Bosch brand unit that they had and replaced the spark plugs again with NGK's by their recommendation. After they reset the code, the car is fine. But it still idles a little rougher than it should when in drive. It used to be smoother. Anything else to check or clean? The car never had any other issues other than this.
Old Dec 19, 2002 | 09:40 AM
3.3.3's Avatar
Default Re: slightly rough idle problem (shahram72)
car might be running a little rich...did you look at the spark plugs yourself? if theyre nice and black, eh....
Old Dec 19, 2002 | 10:49 AM
shahram72's Avatar
Default Re: slightly rough idle problem (maks)
Sounds likely. Plugs were kinda black. How do I adjust this? It is adjustable? I thought the computer controlled this.
Lewsears
Mar 20, 2010 09:25 AM
magicwidget
Apr 20, 2008 12:00 PM
92jdmhatch
Honda S2000
20
Sep 5, 2006 04:33 PM
sidewayz32
Sep 28, 2005 10:14 AM
bennyhonda7
Jun 21, 2005 12:49 PM
