Honda S2000 Honda S2000
Help: Wierd Missfire
Old Jun 17, 2006 | 09:34 AM
92jdmhatch's Avatar
Default Help: Wierd Missfire
So I had NGK v-power plugs instead of the OEM double platinum plugs, the car would start missfiring or stuttering at very random times...ie: sometimes when i am taking off in first ..it stutters....or when im in any gear at low rpm it will stutter a little....also the idle began to drop as low as 300rpm or sometimes it even shut off everytime i came to a stop....so i figured change the plugs to the original ones...i put those in...got a little worst....next night i got a check engine code saying ( System Too Rich, Bank 1) bank 1 = .oxygen sensor before cat....next morning randomly the idle got okay but still stuttering....i tried changing the coils with my friends s2k but the problem is still there but no bad idle....someone said check o2 sensors....i opened them up and looked at them...they arent that bad...to me it almost seems like im loosing spark somewhere..the cylinder is not burning the fuel and thats why my o2 sensor is reading rich...any ideas?
Old Jun 17, 2006 | 09:38 AM
DC2's Avatar
DC2
Default Re: Help: Wierd Missfire (92jdmhatch)
Go back to your stock plugs and gap them correctly, see what happens.
Old Jun 17, 2006 | 10:00 AM
92jdmhatch's Avatar
Default Re: Help: Wierd Missfire (DC2)
i do have stock plugs...my stock plugs had originally gone bad...at the time i didnt have money to buy the oem plugs so i got some V-Power NGK's to use temporarily...but with the problem..i said expletive it...i will pick up some oem ones...which is wut they r...and they r gapped correctly
Old Jun 17, 2006 | 02:04 PM
92jdmhatch's Avatar
anyone?
Old Jun 17, 2006 | 02:09 PM
WowOzYouRock's Avatar
your ign. coil might be bad
Old Jun 17, 2006 | 02:56 PM
92jdmhatch's Avatar
Default Re: Help: Wierd Missfire (FR-MOB: Jerk)
well s2k has individual coils....and i just said that i replaced those...
Old Jun 17, 2006 | 04:49 PM
vpforeva's Avatar
New User
your check engine light code is telling u what the problem is for your misfire, your o2 sensor, test it with a multimeter or swap in a good one and see if the problem goes away.
Old Jun 18, 2006 | 02:03 AM
92jdmhatch's Avatar
Default Re: Help: Wierd Missfire (vpforeva)
well i was thinkin it was the o2 sensor as well...im going to go ahead and swap that one out and see if it makes a difference.......buttt...the reason i thought it couldnt be the o2 sensor is because.....the o2 sensor is the only thing that tells wut ur air to fuel mixture is inside the motor.....and so i figured something from up there (plug, coil, or anything ) is not functioning correctly and the o2 sensor is reading it being bad....but im goin to try swappin a o2 sensor out 2maro
Old Jun 18, 2006 | 03:00 AM
mykcuz's Avatar
if ur sensor is bad, looking at it wont tell u nething, sometimes u just get a bad one, and sometimes u will replace it with a brand new one that is bad, ur injectors may be clogged so the engine forces more fuel into the engine to over correct, sometimes that happens, and if ur in a higher mialge car that will happen. my 05 s2k studders sometimes coming to a stop at idle, dont know y, but its not all the time. in a rush more later...
Old Jun 18, 2006 | 09:57 PM
vpforeva's Avatar
New User
your o2 sensor is probably stuck lean, so the computer is only seeing a lean value from the o2 instead of lean rich lean rich, so it compensates by adding more fuel, thats why u have the system too rich code
Old Jun 18, 2006 | 10:46 PM
JEFFOS69's Avatar
Also could be your MAP sensor - check S2ki and read up on the map whack fix. Apparently they are a problematic piece but easy to fix with a few good whacks and and ecu reset every once in awhile. I had a similar problem and I fixed it the same way. (Low idle, almost stalling when slowing and stopping, sputtering sometimes)
Edit - I would also change your plugs back to stock - might as well.
Old Jun 18, 2006 | 11:20 PM
92jdmhatch's Avatar
Default Re: Help: Wierd Missfire (JEFFOS69)
yeee but my sputtering isnt SOMETIMES......its every time i drive the car....except at random times while driving.....but its gauranteed to act funny everytime u drive it...iit almost seems like its not getting correct spark..... but then again the plugs r oem and gapped correctly..and the coils have been changed.....and my map sensor i have already changed to a brand new one
Old Jun 19, 2006 | 01:53 AM
Mr. Projekt's Avatar
* B A N N E D *
Regarding the MAP whack, it's not because of a faulty sensor itself, but the tiny port that it is bolted to. Unbolt the MAP sensor and make sure it's clean and oil/dirt free. Reset the ECU, recheck the gap plugs, reset the idle, and try again.
Old Jun 19, 2006 | 12:17 PM
JEFFOS69's Avatar
Default Re: Help: Wierd Missfire (FR-MOB: Projekt)
Yup its true its not because the sensor is faulty it just needs to be cleaned or whacked and its back to 100%. They even did a few tests and a new sensor worked just as well. Its just the way that works and designed (not on purpose but its just one of those things) Its worth doing alongside of the few other things - it is a free thing to do and only takes a few minutes, you may be surprised.
Old Jun 19, 2006 | 03:55 PM
92jdmhatch's Avatar
got a link to the s2ki map sensor fix thingy?
Old Jun 19, 2006 | 07:40 PM
JEFFOS69's Avatar
http://www.s2ki.com/forums/ind...86868
http://www.s2ki.com/forums/ind...09708
Modified by JEFFOS69 at 4:52 AM 6/20/2006
Old Aug 22, 2006 | 10:46 AM
92jdmhatch's Avatar
i tried changing my Oxygen sensors and it drove fine for a couple of days but then it started givin me the same problem....when i first turn it on in the morning it starts up and starts idling VERY odd....or it just turns off..when i drive it...its almost like im running on 3 cylinders because the car doesnt move..then all of a sudden it kicks and it starts driving normal again and then next gear does it again... could a bad TPS or bad IAC cause this? how could i test my coils? or my injectors?
Old Aug 22, 2006 | 11:58 AM
Mase's Avatar
first, are you running a stock ecu? what modifications do u have done?
next, id probably do a compression or leak down test, make sure your motor isnt hurt.
then id start looking into various sensors.
Old Aug 22, 2006 | 02:42 PM
92jdmhatch's Avatar
Default Re: Help: Wierd Missfire (Mase)
running a stock ecu......only mods i have is an intake....i guess i will do a compression test first and figure this out
Old Aug 27, 2006 | 02:16 PM
92jdmhatch's Avatar
Finally got a check engine.....got the same one as before - System to Rick Bank 1. however i got another one with that one (P0170) fuel trim malfunction....any ideas anyone?
Old Sep 5, 2006 | 04:33 PM
naTRON's Avatar
did this problem ever get solved? just got the same codes from my em1....
9thgenidiot
Jun 24, 2015 01:12 PM
Ash J. Williams
Jan 28, 2011 02:16 PM
Sticky2K
Mar 31, 2010 08:02 AM
awdriscol4
Apr 26, 2005 02:45 PM
shahram72
Dec 19, 2002 10:49 AM
