Tires rubbing on top!!!! Insite to a cure????
So I have a coupe with Comptech springs (1.5 all around) and 205-40-17s. My tires rub aginst the top of the finder well where I assume the sheet metal of the fender\quarter panel, meets the body of the engine bay, and bends down towards the ground..... I hope this is making sense, it happens when I turn hard of course.
Done - I have taken the lining out on one side to see if that would help, but it didn't.
Question - Rolling the fenders will help some, but can i bend that piece up above the tire with out damaging anything???????
Side bar - My alignment is way off and pulls to the right, due to the recient drop, getting it fixed tomorrow...... The front drivers side seems to be the worst rubbin..
I know this is a dumb post, but I need to know what you guys do to fix this. I have seen coupes with 18s slammed to the ground, but they don't rub! What is the trick to fix this annoying problem????????????
PLEASE HELP!
[Modified by greebler, 8:33 AM 12/19/2002]
[Modified by greebler, 7:14 AM 12/20/2002]
PLEASE HELP!
PLEASE HELP!
PLEASE HELP!
[Modified by GAMEOVER 1.8, 9:05 AM 12/19/2002]
Well it cant be rubbing the top of the fender because your car is only has a 1.5 drop which still leaves a finger or two gap correct? I believe it's just rubbing the inner wall where the mudd flaps are right? Well i say just take it easy on them turns. Dont turn the wheel all the way i guess.
it sounds like its your alignment/toe, you're probably rubbing in the inside. I had to same problem when i had my car slammed, and it only rubbed when i turned all the way
SoyMilk
Apr 22, 2007 03:53 PM
black sohc civic
Oct 18, 2003 09:42 PM
ochdog
Aug 9, 2002 12:05 PM
