gsr head itr cams valve clearance question
Old Dec 18, 2002 | 08:54 PM
darrinbrewer's Avatar
Default gsr head itr cams valve clearance question
for a stock 94 gsr head.. will any year ITR cams work? what year should i buy when i get them?..then when i get my valves adjusted -should they be gsr spec or ITR spec clearances? or are they the same valve clearances?
Old Dec 18, 2002 | 08:56 PM
Quik Chris's Avatar
Default Re: gsr head itr cams valve clearance question (darrinbrewer)
Any year ITR cam will work, they're all the same spec: 11.5mm lift, 240deg duration (intake side).
Adjust to ITR spec.
You're getting the ITR valve springs and retainers for them right?
Old Dec 18, 2002 | 09:15 PM
Default Re: gsr head itr cams valve clearance question (Midori Shinkansen)
probably not getting spring and retainers, i'm not planning on going past 8000RPM
Old Dec 18, 2002 | 09:29 PM
Colin's Avatar
any year itr will work. but you should try to get the 01 ITR's....because they are the same spec as the CTR cams.
Old Dec 18, 2002 | 11:51 PM
Quik Chris's Avatar
Default Re: gsr head itr cams valve clearance question (91IntegGS)
The only difference in ITR and CTR cams is 3 deg duration, and ITRs are all 240deg.
I'd do springs and retainers since you're in there. Plus, you're not getting the full benefit of the cam if you don't raise the redline.
Aside from that, even if you do keep the stock redline, the valves still accelerate at a faster rate than before if you change to a more agressive lobe profile, which can still cause valve float, it's not just an RPM thing.
Old Dec 19, 2002 | 01:03 AM
tony415's Avatar
yup, only difference is the intake side. exhaust is the same. all b-series vtec motor have the same valve spec.
Old Dec 19, 2002 | 01:33 AM
Buckshot's Avatar
Default Re: gsr head itr cams valve clearance question (tony415)
if you just drop in the itr cams on the stock gsr head what should u adjust the valve clearences to?
do gsr and itr have the same?
Old Dec 19, 2002 | 08:23 AM
IN VTEC's Avatar
Default Re: gsr head itr cams valve clearance question (Buckshot)
Valve clearances are the same.
kill y-tee
Jan 19, 2007 07:08 PM
Formula
Mar 16, 2006 08:06 PM
IntegraGuy16
Jan 2, 2006 02:26 PM
4dooritr
Jan 4, 2005 09:11 PM
dLo GSR-stolen-now-WRX
Nov 18, 2002 09:03 PM
