Why do N/A people get forged pistons?
Old Dec 18, 2002 | 12:05 PM
Halo's Avatar
Default Why do N/A people get forged pistons?
Why do you N/A guys get forged pistons over the factory psitons? Please someone explain to me what a forged piston offers that ctr or itr piston doesn't?
Old Dec 18, 2002 | 12:09 PM
IN VTEC's Avatar
Default Re: Why do N/A people get forged pistons? (Halo)
Larger bore size. Factory pistons are only available up to .25mm oversized.
Old Dec 18, 2002 | 12:13 PM
Halo's Avatar
Default Re: Why do N/A people get forged pistons? (IN VTEC)
ok good point, but let's assume 81mmCTR/ITR VS 81mm Forged
Old Dec 18, 2002 | 01:36 PM
JeremyL's Avatar
better heat tolerance, possibly allowing for maybe better rings or differently setup ring lands, another reason maybe to run higher compression
Old Dec 18, 2002 | 02:06 PM
zilverz's Avatar
Stronger Piston .. can take more abuse ... ummm Raise compression ... can buy oversized ones .. if you bore your cylinders ... different dish/dome types ? like Flattop ect..
Old Dec 18, 2002 | 02:13 PM
blacksheep's Avatar
Those are the ones who have too much money to spend. I have to build my car on a budget.
But seriously, there are more different types (bore and compression wise) with forged pistons versus factory pistons. But they are more expensive than factory.
Old Dec 18, 2002 | 02:18 PM
teg92's Avatar
First off anyone over 81.5mm have to go with forged...
The reasons I am going with forged
- Lighter (rev easier, less wear on everything)
- Retain much less heat (less prone to detonation, can run slightly higher CRs)
- Stronger (always better)
- More specific choices of compression ratios
- Bigger valve reliefs
Here are some random tidbits of information...
Forged aluminum pistons have much denser molecular structure than cast pistons, so heat transfer through the forged material more quickly. Also different parts of the piston expand at different rates. There is more metal around the pi-bosses than in the skirts, so these two areas grow to different sizes when heated. This is why arr engine that is noisy when first started on cold morning can run quietly after it has warmed up. As the pistons are brought up to operating temperature, they expand to create the proper clearances.
Old Dec 18, 2002 | 02:23 PM
IN VTEC's Avatar
Default Re: Why do N/A people get forged pistons? (JeremyL)
You can achieve a wide range of compression ratios by mixing and matching OEM Honda pistons (and/or heads where cost effective and design allowed).
Altho, depending on the combination, you're pretty much limited to 12.0:1 using OEM Honda stuff. If you need to a lot higher than that (even further than milling & a thinner headgasket will get you), your only options are aftermarket forged pistons.
I don't know all that much about all the detailed rules racing sanctioning bodies and their classes, but I don't think there are any classes that restrict you to original bore and stroke while allowing you to change the internals for non-original pieces, without throwing you into the next class up. I could be wrong on this. So, if you are going to use forged pistons, you might as well be sleeving and overboring while you're at it.
If you're not racing, then you don't have to worry about this. Instead, you'll need to consider the cost-effectiveness of the advantages of using forged pistons in the std 81mm bore for a NA application. Since you can hit almost any "streetable" compression ratio using OEM Honda pistons (which are half the cost of forged ones) and the other benefits (ie: ring land strength and ring placement) are pretty much negligible for non-racing application, I think it's a no-brainer on which ones to use.
Old Dec 18, 2002 | 03:03 PM
JCushing's Avatar
basically for 81mm or 81.25mm on a street car i would just use oem honda pistons. as mentioned before there half the cost and you can get anything 12:1 and under. and R piston comes with a molly coating too so there pretty good on a budget.. however for a serious build (by serious i mean 12:1 +, 81.5mm + or 9k+ ) i would say forged. CR and bore are obvious cause thats the max you can go with oem but when you start revvin high weight matters and forged = lighter. also forged will dissapate heat faster as well. i say for the average person that just wants a bump of power to match some R cams or maybe stage 1 skunks/ toda a's oem is fine but beyond that forged becomes important.
Old Dec 18, 2002 | 03:35 PM
dohcsideSi's Avatar
Default Re: Why do N/A people get forged pistons? (teg92)
that pretty much sums it up...
and for those who think milling and decking are a way to up the compression i hope your not running a real set of cams:
jun 3, skunk stage 3, toda c+d's need stock height heads for you to sleep at night
Old Dec 18, 2002 | 03:48 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Why do N/A people get forged pistons? (dohcsideSi)
i've always wondered... why does Honda sell overbored pistons? woudln't they want all replacement parts (as that is what they are) to be the same?
Old Dec 18, 2002 | 03:55 PM
IN VTEC's Avatar
Default Re: Why do N/A people get forged pistons? (dLo GSR)
You can barely even call a .25mm overbore an overbore.
Honda made them available to account for situations where the engine would have to be rebuilt without having to replace the cylinder sleeves, which is a lot more expensive than just replacing a set of pistons.
Old Dec 18, 2002 | 04:01 PM
threatcon13's Avatar
New User
Old Dec 18, 2002 | 04:02 PM
Paste's Avatar
Loved
Has anyone seen the forged ITR pistons, no their not made by honda.
Old Dec 18, 2002 | 10:34 PM
Halo's Avatar
Default Re: Why do N/A people get forged pistons? (paste)
I believe the pistons you are talking about are made by probe ind paste......Personaly I have yet to see a piston with as tight a clearance as factory..For 81 mm and N/A I can't imagine a better piston than ctr
Old Dec 18, 2002 | 10:55 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Nice chart. I have always wondered about this.
Old Dec 19, 2002 | 07:35 AM
vtec69's Avatar
Default Re: Why do N/A people get forged pistons? (FrostyDC4)
deeper valve groves
better performance
variety of compression and bores
-Brian
Old Dec 19, 2002 | 07:40 AM
Civichatch2k's Avatar
i would say high heat handling, the pistons are a harder material, and they do allow for many more ranges of compression.
black D
Honda Civic (2001 - 2005)
May 17, 2011 12:28 PM
Ryan#1
Oct 2, 2008 06:27 PM
dkrex001
Nov 23, 2006 04:52 PM
PrecisionH23a
Mar 17, 2005 06:12 PM
b20ek
Apr 18, 2003 02:37 PM
