b18a1 what pistons
Re: b18a1 what pistons (Ak_ef9)
piston selection is diffucult, it all depends on how extreme you are wanting to go. This also depends on:
1. bore size
2. rod selection
3. crank selection
If you exceed the piston to deck height with using a set of pistons not compatible with the rods or crank, the pistons will literally run into the head. IMO I would go for a set of p30s they're a very good piston for the money, and depending on your application can yeild some very good numbers with the right tune, also you will run into very few problems running these pistons, as they are not as high compression as the ctr or even the itr by a very small margin.
1. bore size
2. rod selection
3. crank selection
