Clutch master cylinder
Old Dec 18, 2002 | 08:14 AM
renes's Avatar
Default Clutch master cylinder
Well it is good to be back. I haven't been here for quite some time. Long enough that my user name has been purged. Anyway I just recently developed a leak in the plunger of the clutch master cylinder. It is bad enough that this morning I didn't have enought fluid in the resevoir to even put the car in gear. I'll try to install a new one tonight. My question is how do you blead a hydrolic clutch? Is it the same as brakes? I haven't seen a bleader valve. I'm picking up a Haynes book tonight for my car. Hopefully it can answer some of my questions. If anyone would like to offer hints on this project I'd appreciate it. Thanks.
Old Dec 18, 2002 | 08:30 AM
Ricky Rojales's Avatar
Default Re: Clutch master cylinder (renes)
Get a Helm's instead. It will answer questions you haven't even concocted yet.
Old Dec 18, 2002 | 10:43 AM
Mt3c's Avatar
25 Year Member
yes, save your money for a helms.
And yes, you do need to bleed the clutch system. in front of the transmission, left of the engine block stamp, slave cylinder with bleeder valve.
Old Dec 18, 2002 | 06:49 PM
hondamanwill's Avatar
bleed screw is at the slave cly by the tranny. bleed just like brakes, may have to pull pedal up with hand.
lil vin
Jun 21, 2014 01:30 PM
ozh_hawaiian
Dec 3, 2011 03:28 PM
RDAYA0
Dec 14, 2006 05:31 PM
Problemo
Oct 13, 2005 01:12 PM
3rdGteg
Nov 5, 2002 01:21 PM
