Tein HR: Spring Rates
Old Dec 17, 2002 | 09:18 PM
BenB's Avatar
Default Tein HR: Spring Rates
Can anyone direct me to some info the springrates for the Tein HR?
Thanks.
Old Dec 17, 2002 | 09:28 PM
JDM CTR '00's Avatar
Default Re: Tein HR: Spring Rates (BenB)
i thought it said it on their site.
Old Dec 17, 2002 | 09:58 PM
IN VTEC's Avatar
Default Re: Tein HR: Spring Rates (ChargedSi99)
They've discontinued the HA's, HR's for the DC2R's. The HR's should have the smae standard spring as teh HA's. I think they were 8k front and 6k rear.
Altho, the range of springs that you can get go from 7k to 10k front and 5k to 8k rear, in 1k kg/mm increments.
5k kg/mm = 279.5 lb/in
6k kg/mm = 335.4 lb/in
7k kg/mm = 391.3 lb/in
8k kg/mm = 447.2 lb/in
9k kg/mm = 503.1 lb/in
10k kg/mm = 559.0 lb/in
Old Dec 17, 2002 | 10:32 PM
BenB's Avatar
Default Re: Tein HR: Spring Rates (IN VTEC)
I can't find it on their site. The HRs I'm going to purchase through a local...so if its the same as the HA's...whats the standard?
Thanks.
Old Dec 17, 2002 | 10:35 PM
BenB's Avatar
Nm...I found it 8k/6k. Thanks anyways guys.
Old Dec 18, 2002 | 04:41 AM
Asahi's Avatar
http://www.tein.co.jp no longer available in the US but still mad ein Japan.
and 8/6 is right for standard rates.
stevenEK9
Suspension & Brakes
Dec 8, 2008 03:41 AM
eluam
Oct 20, 2008 08:11 AM
1SlowB16EF
Suspension & Brakes
11
Oct 21, 2006 07:36 AM
speedminded
Oct 21, 2004 06:44 PM
Benny Z
Jan 23, 2004 07:32 AM
