B16 all motor c/r
Old Dec 17, 2002 | 03:52 PM
-16V-'s Avatar
Default B16 all motor c/r
A guys i have a b16 and rebuilding the motor for a n/a setup and just woundering how high of a c/r i could run?
I think my stock pistons are around 10 some thing....
p.s what are the pros and cons of a high c/r on a all motor b16....
Thanx
[Modified by 1991_jdm_sleeper, 12:53 AM 12/18/2002]
Old Dec 17, 2002 | 03:56 PM
johnzm's Avatar
Default Re: B16 all motor c/r (1991_jdm_sleeper)
run 15.0 comp pistons. itll be fast.
Old Dec 17, 2002 | 03:58 PM
-16V-'s Avatar
Default Re: B16 all motor c/r (johnzm)
with 92 octane lol
Old Dec 17, 2002 | 04:01 PM
johnzm's Avatar
oh. its all about the dynamic compression man. u can go higher comp if u get wider cams. more overlap leaks more compression out. go with 11.5:1 that would be good for pump gas i bet since the JDM R is using ~11:1 and runs on 92
Old Dec 17, 2002 | 04:08 PM
-16V-'s Avatar
will my engine be a lil easyer to blow with a 11:1 c/r?
still learning about the c/r
So if i get ctr cams and the ctr pistons would that be a good combo?
[Modified by 1991_jdm_sleeper, 1:09 AM 12/18/2002]
Old Dec 17, 2002 | 04:12 PM
johnzm's Avatar
hey, honda uses it for a reason. its a good combo.
Old Dec 17, 2002 | 04:18 PM
Rydaddy's Avatar
I have CTR pistons for sale/trade. Hit me up on IM.
Old Dec 17, 2002 | 04:54 PM
Ovl55rag's Avatar
you say you want CTR pistons. I want some to. Will they go in with out any mods or what.
Old Dec 17, 2002 | 05:23 PM
-16V-'s Avatar
Default Re: B16 all motor c/r (Ovl55rag)
yea they have stock bore ctr pistons and .25 over pistons but you would need to bore your block....
Old Dec 17, 2002 | 09:33 PM
spettinger's Avatar
from what i understand, the CTR piston in the B16A block only yields a 10.8 to 1 c/r ratio. i am considering balancing the bottom end, mugen headgasket, and a slight mill job on the head for a cheap high compression B16.
Old Dec 18, 2002 | 07:56 AM
PhatOptimo's Avatar
Default Re: B16 all motor c/r (wreckedhatch)
B16/CTr slugs. Sounds very familiar to me. My CTRs ate std though. The only mod needed is to mill the small ends of the rods. The pistons will not fit PR3 without this mod. Any machine shop that presses the pistons on the rod will be able to do this. Also look into ARP rod studs for the B18 (9mm) the 1.6 are all 8mm which will not fit the PR3 rod. I been through that freekin headache. The mugen geadgasket will get you an extra .2 compression. I had it and its not worth it IMO. Especiall for the price they ask for it when tou can get oem and modify it for less than half the Mugen HG. CTR slugs are 81mm with an overbore option of .25mm and .5mm. Of course the machine shop will do the boring and honing. The are a excelent all motor upgrade for the B16 & B18. They are very streetable and do very well on pump gass. Check them out.
[Modified by Phat_Optimo, 11:01 AM 12/18/2002]
Old Dec 18, 2002 | 08:02 AM
-16V-'s Avatar
Default Re: B16 all motor c/r (Phat_Optimo)
Thanx for that info and pic phat
But since the dome on the ctr piston is higher wont you need to adjust your valves?
Or can you just drop them in?
[Modified by 1991_jdm_sleeper, 5:04 PM 12/18/2002]
Old Dec 18, 2002 | 09:05 AM
QWKPHKR's Avatar
Nope, have these pistons in my B16 and have no problems what so ever, I was kinda paranoid about it in the beginning but.. you have nothing to worry about..
Thanks
Old Dec 18, 2002 | 03:29 PM
dohcsideSi's Avatar
Default Re: B16 all motor c/r (QWKPHKR)
25:1 maybe that will make up for that lack of torque...
<----2.0lt... 13:1 c/r daily.
Old Dec 18, 2002 | 05:09 PM
CHRIS 1.8's Avatar
lol
alphanumeric
19
Feb 27, 2005 02:20 AM
KillaB-
Sep 19, 2004 06:01 PM
KillaB-
Sep 19, 2004 10:34 AM
hondacrx90
Jun 21, 2004 06:06 PM
Bulldogg83
Sep 20, 2003 08:52 AM
